Results 1 to 5 of 5
Thread: Can use an Xcal 1 on my 3.0 CSVT
    Default Can use an Xcal 1 on my 3.0 CSVT
    Well my work is trying to get rid of a new blank Xcal 1 and they will sell it to me cheap. so my question is can i use it,, and how can i use it. do i have to basically use it for a dyno tune or is there somewhere that i can get a premade program for a 3.0 CSVT with #19 injectors.
    thanks for any input in advance
    Toreador 98 CSVT #246 of 6535 (3L DONE!!!)
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    read these for the differences between the Xcal1 and Xcal2
    link 1
    link 2
    sounds like they do the same thing but the Xcal2 lets you adjust parameters, data log and clear DTC ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    link 1
    link 2
    thanks for the info,, it seems like the xcal2s features that everyone loves are ones that i really don't need,, i won't be changing parameters all the time,, don't care about code reading or changing tire size and axle ratio.
    but will the xcal 1 be able to shut off the secondaries,, cause i removed them and it is throwing a cel for them so as long as i can have that programmed out with the xcal 1 i will be good
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    Quote Originally Posted by LLADNAR View Post
    I would think that that would all be within the tune ... but I am sure warmonger can answer that one better then I can ...
    - 95 Mystique LS
    lol, Honestly I can't. I've never used an XCAL1 and I know there were compatibility issues between the tunes for the 1 and the 2.
    I'll have to see if I can program the 1 before I can answer.
    My project website
