Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 23
Thread: CSVT v. SSR?
    Default CSVT v. SSR?
    Got a good friend that wants to run me at the track. I've got a stock CSVT and she has the 300HP SSR. She has taken it to the track and ran consistent 15.2's, with varying traps. Now considering what I've read this is a fairly similar time for stock CSVT's, yeah? Would it just come down to a driver's mod?
    -Jon
    2003 Chrysler PT Cruiser GT - Getrag 5 - Speed
    -Air Box mod w/ Drop-in K&N
    -Booger Bushings
    -Flameball Cue Ball Shift knob
    She'll beat ya.
    98.5 SVT-187whp-whawhawheel bearing.
    96 ATX Zetec-alive but scarred!
    FS: $100 off $200 or more SPEC purchase
    depends on how good of a driver you are..... lol
    1998 red CSVT
    02' 3l hybrid swap, MSDS headers, KKM intake, UD pulleys, Brenspeed tune, DMD
    poly mounts
    Jul 2004
    Michigan
    6,096
    Quote Originally Posted by primalzer1998 View Post
    15.2 fairly similar time for stock CSVT's, yeah? -Jon
    Well jon, no its not/ 15.4-15.7 is what contour runs.
    Most decent drivers in stock form svt make it to 15.4's. Really goo drivers can get it down to 15.0's flat.
    Now are u a experienced driver??
    what year svt do u have.
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
    Yeah I'll probably be that 15.4-15.7 range. I'm not too experienced at all. Drive my car a lot but I don't do too much WOT shifting. Mostly do economy driving. I have a '98 CSVT, so I would assume that it would be a little slower than normal.
    Another question, when shifting at WOT at the track, you want to let off the gas yes? I have a friend who shifts without letting up. I guess I wouldn't be that fast, and it would probably hurt my time rather than gaining anything.
    -Jon
    -Booger Bushings
    Slamming the gears without lifting in a stock or even midly modified SVT MIGHT gain you 2-4 HUNDRETHS (read: max, a quarter of a tenth or so.)
    What it is COSTING YOU, though, is going to be MUCH more expensive. Don't waste your time. In your car, with your skills, and your mods, vs a consistent 15.2 trap; you won't win.
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    I did well VS a earlier SSR with the smaller engine 5.3 litre, dead even till he miss shifted.
    2000 Silver Frost/Midnight Blue #564/2150
    2000 Toreador Red/Prarie Tan #576/2150 Project: Tour De Force, Revived 4/25/09
    1999 Mystique White/Prarie Tan Zetec ATX 55k (sold)
    don't waste your time powershifting unless you've got the funds for a tranny rebuild...
    what kind of trap speed was it hitting?
  9. #9
    Jul 2004
    Michigan
    6,096
    -Jon
    Let me ask you to try this. Go to your car and rev on it while in neutral. See how fast it revs? Think now, if you were in first gear and reving to 7k and you kept ur foot down then shifted, you would hit your rev meter. Not allowing you to rev higher. SO it would be pointless.
    I love new car owners that tell me they power shift lol.
    Or lets say you bought a chip!!
    Then first gear would still not be able to power shift. As soon as you release that clutch at 7k, the rpms will fly so fast soo high, when you finally shift you will be hitting your 6-7k rpms mark in 2nd. Again streacthing out our power band to a merely 1k rpms.
    Now on race cars its different. We get what they call a clutchless transmission. Pull lever back and shift. Internal clutch.
    By the way 1998 models were the ones running 15.6's to 15.7's
  10. #10
    There is a reason to powershift on some cars. Like srt4s, it allows the boost to not drop off (which if you shift quickly, doesn't really matter). They were actually designed with power shifting being beneficial to 1/4 mile times but it is bad on the tranny.
