Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 22
Thread: Hi-perf Parts Don't fit! :*(
    Mar 2003
    Alexandria, VA (9m south of DC-towne)
    56
    Default Hi-perf Parts Don't fit! :*(
    Folks,
    My mechanic could not get the following parts to work with my 96 Contour GL-Sport:
    FRPP ZX-3 cylinder head
    Unorthodox U/D pulley
    Mustang throttle body,
    Tru-benz exhaust (for early Zetecs)
    Focus Zetec headers.
    Is there anyone in the DC-area that y'awl would recommend for installation of the parts?
    Thanks,
    Shamoon
    96 GL-Sport 2.0L, MTX
    Bernardo Bourges' CTA CAI,
    Dmitri's SVT E0s rims, 205/55R-16, Dunlop SPs.
    Mr. Shamun "Shamoon" Mahmud, MBA
    Aapex Mortgage - Branch Owner
    direct: 703-887-2214
    fax: 703-997-2283
    Dec 2006
    Coconut Creek, FL
    1,530
    Dude,
    The Focus Zetec and Contour Zetec are totally different layouts.
    The Escort ZX2 Zetec and Contour Zetec are more closly matched.
    Brent & Kim (SVTFLEA) • Coconut Creek, FL
    2000 CSVT • 1890 / 2150 • Black / Tan
    Born: 1/26/2000 • Adopted: 8/4/2006
    Blown Engine: 8/19/2007 • Reborn: 11/2/2007
    Quote Originally Posted by Brent372 View Post
    Dude,
    No.
    pre98 zetec and focus zetec are very simalar.
    post98 zetec and escort zx2 are basically the same.
    your parts should fit (with minor modification)
    98' Contour SVT #2037- 132k, (blk/mnb) 04' 3L ported w/ SVT cams
    Chevrolet Blazer- 111k, mostly stock
    if i remember correctly, i think that the SVT FOCUS headers are the headers that fit on the Zetec. but i could be completly wrong on that. lol...
    someone want to confirm (or disprove lol) my memory?
    kevin m
    98 T-red mystique gs
    zetec ATX
    (*Oo\|||*|||/oO*)
    |My Car| |My Photos|
    Quote Originally Posted by mystiquevltwin View Post
    The SVT focus motor I believe was actually a VCT motor, unlike the other zetec foci. But I have been hearing that ZX2 Zetec and Cougar Zetec motor parts work fine on the Contour Zetec, provided that its a post 97.
    www.ZXtuner.com has some mods for the pre98 Zetec. I think you can get an esslinger UDP, a CF hood, and a few other odds and ends there for the contour Zetec, they do have more post97 parts then pre98 parts though.
    Gone.
    Quote Originally Posted by AliasJerk View Post
    Different kind of VCT, SVT focus has VCT on intake cam as opposed to the VCT on the exhaust cam on Contour/Escort... not sure if it makes a difference, but it might.
    Aug 2002
    Southeast WI
    1,706
    Run away from your mechanic and find someone that knows something about Contours. Also, do some research before going out a buying a bunch of parts.
    -it will fit just fine as long as you swap over the timing belt plate with the tensioner on it
    -how can a UDP not work? The belt that came with it won't work.
    -no ••••• sherlock. It only kinda bolts up to a FRPP intake manifold. You're going to have to make some funky adapter plate for that one. Either that, or buy a normal Focus Zetec TB which will bolt right up. (But you will need a Focus throttle cable.)
    -is this a Cougar part? Or early Zetec Foci? Anything made for the Cougar should bolt right up.
    -Again, no •••••. Our oilpan is completely different from a Focus. You'd have to chop off the bottom part of the header to make it work.
    I don't mean to sound like a jerk but it really doesn't seem like you did any research.
    If you've got money to burn, I'll take some.
    BP
    --'96 GL * MTX Zetec * Tan with more and more mods-- <<Project Car
    --- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
    FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - FRPP Head - '00 Zetec Engine << FOR SALE (PM me)
    Mar 2003
    West Palm Beach, FL
    8,043
    Good info ButtonPuncher, but I'd like to add that the Cougar Zetec headers will fit the Contour. I don't know if there are any more out there for sale, but ZXtuner used to have them, and you will occasionally see them on Ebay. Be sure you CALL and make sure the item is in stock before you buy, or you could be waiting months for your parts.
    UDP should work fine, but you'll have to get a different belt is all... If your mechanic can't figure that out, then spend your time & money elsewhere because that guy is somebody you'll want to keep AWAY from your car.
  9. #9
    Aug 2002
    Southeast WI
    1,706
    Thanks!
    BTW, Zxtuner doesn't offer them anymore but check out my recent SS header thread. There is acompany making ones that look exactly like the OBX ones.
    BP
  10. Default
    I think the ZX2 is more like the Contour than the Focus... that being said, do you still have to chop the bottom off if you get the ZX2 headers?
    '96 Contour GL ATX
    Mods: Jet Performance chip, Remodified Sleeper Z cold air intake, high flow cat, 2.25" exhaust, HKS Muffler, Friction Reduced Ported Polished head, MSD ignition
    TransFlo High efficiency Transmission cooler.
