Note:
The SVT PCM tune has something to do with the added power of the SVT as well. That tune requires that the SVT run on premium gasoline. The CAMs will CERTAINLY provide a nice boost of added power, & you'll notice it mostly at the top of the rev range, but you will still fall a few HP shy of SVT power levels.
If you're competent enough to perform a cam swap, you might consider saving up & getting greasey up to your elbows by doing a 3L swap. Normally aspirated with your SVT cams, and you've got a real winner there.
