Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: Help!
    Oct 2005
    SouthShore, MA
    1,184
    Default Help!
    my sunroof is currently stuck open in the up position and its raining!!! any ideas??? i have NEVER had any issues at all with my sunroof, please help
    #1586 of 2150
    Silver Frost
    "If it ain't broke, fix it 'til it is"
    Oct 2005
    SouthShore, MA
    1,184
    well i just drove 10 feet and it started working again! wtf? anybody experience that before?
    #1586 of 2150
    Silver Frost
    Needs new gear. www.odometergears.com
    98.5 SVT-187whp-whawhawheel bearing.
    96 ATX Zetec-alive but scarred!
    FS: $100 off $200 or more SPEC purchase
    Mar 2001
    Merrimack NH
    10,074
    Blog Entries
    13
    Next time this happens, pop off the plastic cover and you'll see a bolt you can turn with a wrench to close it. (assuming you keep tools in your trunk!) More detailed info used to be in the main site FAQs but they appear to be broken right now...
    Matthew
    1999 Contour SVT #410
    2008 Subaru Legacy GT Limited 5MT
    Sold: 98.5 Contour SE V6 ATX
    Oct 2005
    SouthShore, MA
    1,184
    Quote Originally Posted by Kremithefrog View Post
    thing is back to working fine...i dont know what the hell its deal was last night
    #1586 of 2150
    Silver Frost
    Quote Originally Posted by RespectTheContour View Post
    The gear is probably stripping. It may work like that on and off. I would replace the gear before opening it again.
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    It got to a melted spot. worked its way around and will end up on that bad spot, again, soon.
    Avoid using your sunroof until you either replace the gear or choose to not care if it gets stuck open.
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Oct 2005
    SouthShore, MA
    1,184
    i should probably add that when it was no working...it was making no noise at all, only noise was the click from me hitting the switch, does that happen if it is the gear? or should i have heard something moving?
    #1586 of 2150
    Silver Frost
  9. #9
    sunroof gears now on ebay!!!!!
  10. #10
    Apr 2002
    Manhattan, Kansas
    858
    I'd say the commutator of the sunroof motor could have been in a dead spot, and the vibration from driving ten feet moved the armature just enough so that the brushes made good contact again. Happens with DC motors.
    -Mark-
    '99 Mystique LS, original owner, 100% stock. 300,000 miles
