Where the h*** is the idle Air Control Valve?
Zetec IAC location.
For the Zetec I-4, you need to access the IAC from the bottom of the car.
IAC cleaning
from Ray's UIM/LIM how to in Duratec Maintenance how to.
"Replacing the IAC gasket:
(From IAC faq)
Over time, the IAC (Idle Air Control) valve becomes sticky due to buildup from the EGR and PCV systems. It can stick partially open such that idle quality is adversely affected, and engine RPM's will not drop below 1500. For a while, blipping the throttle will restore normal idle, but this only works for so long.
The fix is to remove the IAC valve by unbolting the two 8mm bolts that hold it on and disconnected the wiring plug. If you are careful enough, replacement of the gasket will not be necessary. The gasket costs less than US $1.00, so it is no tragedy if you destroy it. Once the valve is off, spray it out with some carb/intake cleaner and make sure any gunky residue is gone. Reattach, and you are done. It is a lot cheaper than a new IAC, which runs around US $70. Note: Ford claims the IAC cannot be cleaned, but this is not true in my experience." Ray.
Location of the IAC for the Zetec.
"It's on the back side of the intake plenum under the throttle body area." DESIGN.
I looked at the Haynes manual and the Zetec IAC valve is located next to the starter. Below are the steps from the 1996 Ford CD to remove it .
Idle Air Control (IAC) Valve
Removal
1. Disconnect battery ground cable
2. Remove the air cleaner outlet tube and resonator assembly.
3. Disconnect the main chassis vacuum line.
4. Disconnect the ignition coil and radio interference capacitor wiring.
5. Remove the fuel line bracket retaining bolt.
6. On 2.0L engine equipped vehicles, raise vehicle on hoist.
7.
7. Disconnect the engine control sensor wiring or fuel charging wiring (depending upon application) from the idle air control valve (IAC valve) at the idle air control valve connector.
8. On 2.5L engine equipped vehicles, remove retainer for engine control sensor wiring from the upper retaining stud bolt.
9. Remove the two idle air control valve retaining bolts or stud bolt (depending upon application).
10. Remove the idle air control valve and idle air control valve gasket.
Installation
1. Note: If scraping is necessary, be careful not to damage idle air control valve or intake manifold idle air control valve gasket surfaces or drop material into intake manifold.
Clean idle air control valve gasket mating surfaces.
2. To install idle air control valve, reverse Removal procedure. Tighten the fuel line bracket bolt to 8-12 N-m (71-106 lb-in).
3. On 2.5L engine equipped vehicles, tighten the retaining bolt and stud bolt to 8-12
4. On 2.0L engine equipped vehicles, tighten the idle air control valve retaining bolts to 8-11 N-m (71-97 lb-in).
IACvalvezetec Idleaircontrol IACvalve
Finally Done With It And It Works
Got it all done and fixed up! 97 Contour, 2.0L, 113k miles.
Bought it from an auction for $200
- Took it for VA safety inspection. Replaced a small length of brake line, flushed brake fluid and a coolant pressure check which was good. SO I THOUGHT.
-The next next day upper radiator hose blew, in turn it over heated which blew my head gasket.
-For the last three weeks I have replaced, head gasket w/new bolts (all other gaskets that come with the head gasket set), IAC valve, MAF (from bone yard), valve job and milling, cable assembly from positive terminal to fuse box,air filter, oil, coolant.
-I also repaired several frailed wiring. I guess there is a problem of the wire insulation..it hardens up.
-And those hose clamps that you have to squeeze with pliers? Those are gone! Replaced them with regular screw on type.
-For my reward, I will go buy a new car stero from Best Buy.
Why in the heck would you raise the car??? The IAC sits on the right side of the throttle body!!
Zetec IAC location.
IAC cleaning
(From IAC faq)
Removal
7.
Installation
no it doesnt. the IAC is mounted to the side of the intake manifold about 3-4 inches below the throttle body on the Zetec.
oh, and way to bring up a 3+ year old post. at least we know you searched:laugh:
