Results 1 to 5 of 5
Thread: SVT Suspension info
    Default SVT Suspension info
    Is it true that the CSVT has a lowered and stiffer suspension than the normal V6 Tour????
    Feb 2006
    lancaster PA
    2,590
    dont kno about lower but the spring rates are different
    Clear/Smoked Reflector GB is on hold. bigger things are happening. Hint they are used a night so you can see
    May 2006
    Glen Ellyn, IL
    2,550
    no it is not true. they are the same hight. its the svt body that makes it look lower.
    -Jon
    99 SVT Contour T-Red. #2437
    www.myspace.com/ripscottfrost
    Mar 2002
    NJ
    942
    Sep 2000
    7,295
    The SVT front springs are the same as the 98 and newer non SVT V6 Contour. The SVT rear springs are the same as the 98 and newer non SVT V6 manual trans non SVT Contour. The rear struts are the same as the non SVT. The front struts are the same on the E0. The front struts are stiffer to reduce lift on acceleration and dive on braking on the E1 and newer SVT.
    I installed the later SVT struts on my E0.
    The ride height of the SVT is the same as the non SVT. The SVT body kit makes it look lower.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
