Page 1 of 2
1 2 LastLast
Results 1 to 10 of 18
Thread: Supercharger head unit options
  1. Default Supercharger head unit options
    Hey, so I've been kicking around an idea I've once briefly heard.
    I really don't care about the A/c, so that'll be removed.
    I want to get a custom bracket made, and put a supercharger head unit where the AC compressor was, and have it run off a custom length [depending on pulley size] (stock location) serpentine belt. I know one rotrex unit can make its way in there, but its like, 2000 dollars.
    I want to run the supercharger--->FMIC--->piping up to the TB almost exactly like a cold air intake would sit.. it would look very sleeper and would be a very simple piping setup, which means the most to me.
    My question is, where can I get a headunit thats more like <1500, that is similar to rotrex units that'll fit in the A/C compressor region?
    Jul 2004
    Michigan
    6,110
    Read This. Someone is already working at building a kit!!
    http://www.newcougar.org/forums/showthread.php?t=100426
    FS:65mm Throttle bodies - SE TB - Zetec TB
    Never explain---your friends do not need it and your enemies will not believe you anyway.
  3. Default
    that bracket is by the water pump, the S/C is NOT where the AC compressor is. Not even close, thats not what im talking about.
    May 2004
    Calgary, Alberta, Canada
    4,506
    Any reason you want to do this over Burrita and toms new turbo kit? 2900 for 290wtrq on stock injectors... yes please.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    It's very hard to find a supercharger headunit under $1700. Jrak over on NECO was working on something similar to this.
    I'm the one building the SC over on NECO posted in the link above. I should be finished fairly soon. I had to order a smaller pulley to clear the tensioner on the 01+ timing covers and I found a universal coolant tank that will fit to cut down on costs. I'll update the post on NECO when I get things running.
    1999 3.0L Cougar Supercharged (10psi)
    2005.5 Audi S4 (340hp AWD winter beater... )
    Visit: http://www.3LDuratec.com for interest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, our Supercharger kit, or anything 3L related.
    Check the link above for a few new pictures of the finished kit.
    Sep 2000
    Louisville, Ky
    9,565
    Looks like a pretty clean install!
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    These guys already have one that goes on the zetec (focus but have been told it will work on the tour), maybe they got one for the 2.5L. I'll start to look and see what I can find.
    http://www.rpmoutlet.com/atimustangf.htm
    jamesmason
    1997 2.0L I4 DOHC Modified
    2001 6.8L V10 F250 S/D
    2006 3.0L V6 Fusion SEL
    “Jargon allows us to camouflage intellectual poverty with verbal extravagance.” — David Pratt
  9. #9
    Quote Originally Posted by Tourige View Post
    Last I heard he was talking to Joey and going to do the turbo.....
    My project website
  10. #10
    Quote Originally Posted by jamesmason View Post
    Nobody has one for the 2.5L, which is why I put one together. Fitting it onto the 2.5L is a nightmare as you can tell by my pictures. Vortech had one for a while and then discontinued it do to issues with the jackshaft.
