Results 1 to 5 of 5
Thread: arp bolt kits
    Default arp bolt kits
    Arp do not list for the 3l . So question is their head and crankcase bolts the same in the 2.5 durate c
    can arp bolts be reused or stretch also
    Aug 2001
    Florida Hoe Hot!
    8,801
    Yes it should be.
    -99 T-RED 3L SVT TURBO
    -99 T-GREEN RHD MPV ST220 MAZDA 6 TURE DUAL 3L SVT
    -00 BLK/TAN SVT
    NEW OEM CONTOUR PARTS DEALER*
    SVTWAREHOUSE.COM COMING SOON!!
    Most ARP bolts can be used again, just follow the directions.
    Don Higgins
    Crew Chief Pro Drag Racing Software
    http://www.crewchiefpro.com
    1999 3.0 Turbo CSVT ** 2013 American Dragster with 1100 Horsepower 7.28 @ 185 mph
    Jun 2014
    England
    9
    Part no 253-4701 is the ARP bolts for 2.5L but are also used for the 3.0L.
    As for re-using them l wouldn't but some do although l guess it depends if your NA or turbocharged etc.
    Jan 2006
    Montreal
    1,048
    The whole point of buying studs over the stock bolts is that they can be reused.
    Quote Originally Posted by GTO600 View Post
    00 Silver Frost SVTC #1429/2150: Born 10 Jan, 2000
    3.0L, Spec Stage 3 Clutch, LSD, Koni Sport Kit +more
Similar Threads
  1. Stainless 3-bolt test pipe for 3-bolt high-flow cat
    By B3NN3TT in forum Performance
    Last Post: 09-11-2013, 09:57 PM
  2. Lower control arm (2 bolt) bolt shifting and making popping sound?
    By rexxdoggy in forum General Troubleshooting
    Last Post: 06-24-2012, 08:11 PM
  3. Replies: 27
    Last Post: 10-08-2010, 06:26 PM
  4. Replies: 4
    Last Post: 11-24-2009, 12:06 PM
  5. Last call for Brake Kits and Mesh Kits at SZ!
    By Stazi in forum Spring Zing
    Last Post: 05-16-2007, 04:01 PM
