Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: Euro Spec MTX-75
    Default Euro Spec MTX-75
    ok from the top... on my 2000 SVT, the tranny failed somehow and any way the case is in 4 parts not the 2 it should be. so i'm looking for a tranny. i could get a reman for 1500 and at SP motorsports i found a eurospec Mtx-75 http://spmotorsports.com/ATCcontour_transaxles.html (sorry i dont know how to make it a link) for 895 New. it claims it will bolt right up. basiclly will it and is it worth it. i'm gonna order it with the quaife LSD. this is a time sensitive matter due to the fact i'm limited to my Kaw. ninja till i get it fixed and i dont like riding in the rain esp. the way the back tire is (bald) so any input is good input. yes i did look too. thanks
    Number 47
    00 Contour SVT Black
    #557 of 2150
    Fabricated Nov 24 1999
    short ram intake/magnaflow exhaust/short throw shifter/ MSDS headers and more to come
    Jul 2004
    Wisconsin
    2,235
    yes it will bolt right up, and the Quaife is a great idea
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
    Oct 2003
    Phoenix AZ, Manch-Vegas at heart
    686
    Do it, it is well worth it.... I just got my cah back with the euro installed and it is awesome... great deal...
    I had Arizona dynoChip do the install it they had no problems with it.
    Keith P.
    Killed in action-4/27/06
    '99 CSVT
    #2369/2760-7/28/99
    **New Recruit**
    1998 EO CSVT
    # soon to come
    Black 106,xxx
    Jul 2001
    Puyallup, WA
    690
    doesn't the euro spec come with a billet open diff? its not a great handling aid like the quaife, but if your trying to save money it should be much more robust than the stock US unit.
    Ohsigmachi
    Old ride: '96 GL MTX Zetec **sold after ten years of ultra-relible service.**
    Newest Ride: 2003 Jaguar S-type R = Superchraged Luxo-rocket
    --I don't want to hurt you, but it's still on my to do list.--
  5. Default
    ^^^really? anyone confirm this? its better than nothing... yea, i really think ill buy one when i do the 3l to my car, can anyone comment on their opinion of the final drive ratio? im excited about this...
    May 2000
    Grand Rapids, MI
    26,860
    Blog Entries
    1
    You know snow is expected the end of this week right? The trans. will get shipped to Terry in Rockford, MI and then onto you most likely. It's not oing to be quick by any means. Hope you have other transportation. I know of a 2 tranny's that you could buy for $250 and have Terry replace worn parts and then have it shipped to you. Probably fastest since I could bring one over to his house as soon as you'd like.
    Sep 2000
    7,331
    Don't forget that the euro spec trans has a taller final drive. Although it will work, the taller gearing will hurt performance unless you have done a alot of mods, like a 3.0 conversion.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Dec 2002
    Boston, MA
    2,550
    Anybody know how much this tranny will effect performance on a 3L?
    2005 Escape Hybrid
    1998 T-Red CSVT Oval Port 3.0L
    190 fwhp, 205tq on stock intake and exhaust
    SVT Intake Manifolds/Cams, Spec stage 2, B&M, Bosal exhaust, K&N, SF Chip, DMD, Pre-98 trunk w/lip spoiler
  9. #9
    Quote Originally Posted by Nate S View Post
    Well since he says it has a taller gear ratio i'm assuming you will actually loose a little holeshot, with your basic 3.0... but you will gain top end and actual gas mileage. (running lower rpms on the highway) If you had enough power (F/I 3L) that you were jamming gears like a mad man in there this would actually benefit you because you could ride out the gears longer.
    00 SVT Silver Frost/Midnight Blue #1321/2150
    99 Cougar V6 5spd Spruce green - SVT powered!
    03 F150 4.2L 5spd Supercab Black
    I guess I have a thing for V6's with manual transmissions?
    www.shineyphotos.com
  10. #10
    Sep 2000
    7,331
    Gearing is always a matter of debate. The taller final drive is a common modification when doing the 3.0 conversion.
    Gearing multiplies torque. If the engine produces significantly more torque, you need less gearing. There is a significant increase in torque with the 3.0 conversion. Keeping the stock gearing will provide wild acceleration, but it also makes 1st gear almost unusable (or unneeded) with the 3.0 conversion. The 3.0 will still perform like gangbusters with the taller gearing, but 1st will be more usable and fuel economy will be better.
    Also the taller gears permit 0 to 60 with 1st and 2nd gear, with stock gearing you will need to shift to 3rd.
    Others will argue for best performance you will want to use even lower gears with the 3.0 conversion.
    Jim Johnson
    98 SVT
    03 Escape Limited
