Engine harness issues Ford Contour V6 CD4E 1995
Merc97
Dallas,TX
Hi i´m having problems with my contour, everything begin´s when i change the vss
the engine won´t start and with the key on, the cooling fans and the fuel pump stays on
the relay of the pcm was burned
i have not idea what can be, maybe a new harness???
Most of the 95-98 Contours experienced issues with the wiring harness. Do you have insulation flaking off the wiring on your car? Is there bare copper wire exposed in spots?
yesterday disconnect all the harness, the wires of the connectors from the vss and another from the transmission are exposed, so i think what this began the short
and i have to get another harness :(
photo.php
Before you buy a new harness, take a look at the main body harness. They can have the same issues the injector and main engine harness has and if it gets bad it may be a lot more work to fix.
Yeah i'm going to review the entire harness, i only check this part of the harness and most of the coverage is bad
attachment.php
[/IMG]
and its hard to fix it???
