Results 1 to 3 of 3
Thread: change to bigger injectors
    Default change to bigger injectors
    I am fairly sure the beige injectors must be pretty well maxed out on full throttle, on my 3l port matched conversion
    when remapped its max was 217 crank hp
    since that I have optomised tb, ported manifolds, cold air feeds to ram air svt airbox
    have just had a set of orange injectors refurbed, will a remap be able to find more power with the bigger injectors , or do you just end up with the same power and a reduced duty cycle
    Jul 2003
    Dallas, Tx
    432
    Do you have duty cycle numbers for the current injectors?
    1999 Silver Frost SVT #259
    Mods: Port-Matched 3L, Magnaflow Exhaust, MSDS Headers, Torsen T-2 LSD, Fidanza Flywheel, Spec 3+ Clutch, 18" OZ Superleggras, Baer BBK, BAT Suspension, Mystique Tail
    Dec 2007
    Peoria, IL
    519
    If your current injectors are truly maxed out, then bigger ones with a proper retune would yield more power.
    What's your current A/F ratio under WOT? Does it change as the rpms increase?
    Sent from my Note 3
    1998 T-Red SVT 115,000 miles (Died 9/01/08)
    2000 Tropic Green SVT #396 - 04 3L, HMS Trans, Wilwood BBK, FSVT Rear BBK, Koni/H&R...NPG Turbo Kit (JUNK)
Similar Threads
  1. Escape Injectors vs. Taurus Injectors
    By TennTechMan in forum Duratec 3L
    Last Post: 02-06-2013, 11:45 PM
  2. 3L, are they better or just bigger?
    By ArcticFrostSVT in forum Duratec 3L
    Last Post: 12-08-2010, 12:56 AM
  3. because bigger is better
    By royalblue in forum Brakes
    Last Post: 10-18-2008, 10:55 PM
  4. when to get bigger injectors?
    By Teal4Banger in forum Zetec Performance
    Last Post: 04-01-2008, 11:26 PM
  5. Just a little bigger
    By hectik1 in forum Pics and Videos
    Last Post: 01-04-2007, 01:16 AM
