Page 1 of 2
1 2 LastLast
Results 1 to 10 of 18
Thread: fuel injectors
    Question fuel injectors
    well, i turbo the zetec....question I want to know is, what size is your factory injectors or what cc's?
    96' contour SE
    ________________________
    TEIN Lowering springs, dual exhaust,
    Aug 2002
    Southeast WI
    1,705
    I'll be nice and start by saying that you need at least 40# injectors, either a Mustang GT MAF or a 80mm Lightning MAF, a bigger fuel pump, a good 1:1 fuel pressure regulator, and a good intercooler. There's still some debate about exactly how big the stock Zetec injectors are. They are between 16 and 19#.
    Now for the rant...
    WTF? You're running 5psi of boost on a bone stock 95? STOP!!! You're gonna blow it up!!!!
    Please tell me you have a chip from SCT to help compensate somehow.
    The TD04-12A only flows 320CFM @ 15psi. A stock zetec will flow 435CFM @ 15psi. You are going to be so far off the map, all you're going to do is make hot air.
    Here's my injector data from the old forum:
    I've seen the question of "How big do my injectors need to be for XXX horsepower?" With more and more Contique Zetecers going FI, here's some good info.
    (injectors size*number of injectors)/0.55=Crank Horsepower
    19# Injectors=(19*4)/0.55=138HP
    24# Injectors=(24*4)/0.55=175HP
    30# Injectors=(30*4)/0.55=218HP
    42# Injectors=(42*4)/0.55=305HP
    50# Injectors=(50*4)/0.55=363HP
    60# Injectors=(60*4)/0.55=436HP
    61# Injectors=(61*4)/0.55=444HP
    71# Injectors=(71*4)/0.55=516HP
    Please keep in mind that these numbers are all for crank horsepower and that you never want to run an injector wide open. With a 90% duty cycle you would get the following...
    19# Injectors=((19*4)/0.55)0.90=124HP
    24# Injectors=((24*4)/0.55)0.90=157HP
    30# Injectors=((30*4)/0.55)0.90=196HP
    42# Injectors=((42*4)/0.55)0.90=275HP
    50# Injectors=((50*4)/0.55)0.90=327HP
    60# Injectors=((60*4)/0.55)0.90=393HP
    61# Injectors=((61*4)/0.55)0.90=399HP
    71# Injectors=((71*4)/0.55)0.90=465HP
    Again, these numbers are all for crank horsepower. You would loose an additional 10-15% of your horsepower with a manual and 15-20% with an ATX.
    You also want high impedance injectors that have Bosch (EV1) style connectors.
    CFM carries them in sets of four and have very good prices. McNews Automotive also carries the Ford Racing injectos in sets of four.
    I hope this helps.
    Later,
    Ben
    I hope that you listen to reason and don't blow up your Zetec.
    BP
    --'96 GL * MTX Zetec * Tan with more and more mods-- <<Project Car
    --- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
    FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - FRPP Head - '00 Zetec Engine << FOR SALE (PM me)
    Unhappy
    Quote Originally Posted by ButtonPuncher View Post
    Now for the rant...
    BP
    thats crazy!! running 5 pounds of boost on my motor is safe... I talked to a turbo guy and he said running 5 psi is safe i should not blow the motor and any reason to blow the motor its because of overboost.....
    96' contour SE
    Mar 2004
    Louisivlle Ky
    5,204
    its only safe if you have the fuel system to match it and running stock injectors is not a good idea.
    im assuming your asking about injector size so you know how much bigger you need to go and not how much boost you can run with the stock injectors.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    Quote Originally Posted by striker2 View Post
    well, i'm asking what is our stock injector size? I'm not running more boost. I'm leaving the boost on 3-5 pounds.....on 5 pounds the stock fuel system should keep up with the turbo...i shouldn't have any problems...
    96' contour SE
    Aug 2002
    Southeast WI
    1,705
    So what tuning are you using? You can't just throw bigger injectors on. Your fuel trims will be soo screwed up. That and you will be maxxing out your stock MAF.
    I'm trying to help. There was another guy on here that just threw a turbo on his Zetec and blew it up. He had a rising rate FPR, stock MAF, and no way of pulling timing.
    Do you at least have a wideband so that you can watch your AFR?
    I want to see you succeed. I swear.
    BP
    Mar 2003
    West Palm Beach, FL
    8,043
    An FMU should be able to bump the fuel pressure up to compensate for 5psi on stock injectors, yes??
    Mar 2004
    Louisivlle Ky
    5,204
    Yes but you still need some way to adjust your ignition timing. also like ButtonPuncher said you are going to max out the stock MAF quickly. IIRC its only good for 7Lbs/min of air flow.
    '00 Black SVTC #391
    Now For Sale
  9. #9
    Talking
    BP
    well, I understand you trying help, I understand that! I'm NOT putting no bigger intjectors in my zetec...A friend of mine that has a turbo tc ask me what cc's injectors I have in my car stock!!! My zetec is not going to blow up.. the only way to blow up the zetec is overboost
    96' contour SE
  10. #10
    Mar 2004
    Louisivlle Ky
    5,204
    overboost or not, if the MAF is maxed out and your moving more air than that then you will not have enough fuel for the amount of air coming in. guess what happens when you have too much air and not enough fuel? thats right it goes "boom". now since i dont have the specs for the stock MAF and a compressor map for your turbo sitting in front of me i cant tell you if your maxing your MAF or not. This is also assuming that the stock injectors can handle the extra amount of fuel they need to supply.
    '00 Black SVTC #391
    Now For Sale
