For Sale Cougar S Gas Pedal Cover
Status
Not open for further replies.
Aaron88
Moderator
Allentown, PA USA
For sale is a Cougar S gas pedal cover. I separated the cover from the pedal assembly in the junkyard. My plan was to use double sided 3M tape and attach the cover to my pedal in-car. Decided to go a different route so it's up for sale.
The cover is made in 3 pieces. The aluminum cover, rubber grip pad, and two plastic inserts where the cover was attached to the factory Cougar pedal.
$10 shipped in the US. PayPal accepted.
If anyone is interested in this. I just installed a full set in my focus. Gas, ATX Brake and Dead. For the gas pedal, you can use metal screws #4/6, 3/4" long and black hinged screw caps. If you get the caps for the correct screws they are the exact same size as the black nubs on the pedal just maybe 1/32-1/16" taller.
Using metal screws into the plastic pedal is how the Autovation gas pedal install.
Just one small story if u dont mind...i put a set of pedals on my merc mystique
the screws ended up stuck into my rear thick rubber floor mats making my clutch pedal
stick to the floor creating a dangerous situation in my small garage
Status
CLASSIFIEDS RULES
Last Updated: 7/20/22
