Results 1 to 5 of 5
Thread: Brake pedal to the floor, no visible fluid leaks
    Sep 2011
    Mt. Vernon, Ohio
    200
    Default Brake pedal to the floor, no visible fluid leaks
    Hi guys, like the title says, overnight my brake pedal went from a normal 'biting' position, to going to the floor today. The reservoir was low but not empty. I cant see any leaks coming form the calipers or any bad brake lines. The only other place i think the fluid could be going is the booster. I'm curious if anyone has had a similar issue or more experience with it.
    I'm about to bleed the brakes so see if it changes anything.
    Thanks
    2000 CSVT, Black and Tan, #0801
    Jan 2006
    Chicago Area
    229
    If you have so visible leaks then your probably right about the fluid leaking into the booster. It may be that the seal on the back of the master is bad or the seals in the master are bad.
    Looks like time for a new master.
    '00' SVT Contour
    '87' VW ITA 16V Scirocco race car
    "Drag racing is for those drivers who can't brake and downshift at the same time."
    Sep 2011
    Mt. Vernon, Ohio
    200
    Thanks, just wanted a second opinion before i start taking things apart.
    Nov 2012
    Medina, OH
    144
    Be sure you check near the fuel tank where the lines typically rust through (like mine did).
    -'98˝ Toreador Red CSVT
    -Some quick SUVs
    Dec 2002
    Portland, Oregon
    846
    Quote Originally Posted by svtbuckeye11 View Post
    hi guys, like the title says, overnight my brake pedal went from a normal 'biting' position, to going to the floor today. The reservoir was low but not empty. I cant see any leaks coming form the calipers or any bad brake lines. The only other place i think the fluid could be going is the booster. I'm curious if anyone has had a similar issue or more experience with it.
    Thanks
    pm sent
Similar Threads
  1. ABS Kicked In, Then Pedal To The Floor?!
    By Wease in forum Brakes
    Last Post: 07-13-2011, 02:23 PM
  2. Brake fluid container, rear SS brake lines
    By FastFord in forum Body/Suspension/Brakes
    Last Post: 05-01-2011, 08:26 PM
  3. Found leaks during brake job
    By pletby in forum General Troubleshooting
    Last Post: 07-25-2009, 11:16 PM
  4. Clutch pedal - meet floor board
    By bohdi in forum Transaxle
    Last Post: 12-10-2007, 05:51 PM
  5. 'Pulsating' Brake Pedal?
    By 96Mystique in forum General Troubleshooting
    Last Post: 11-18-2007, 10:48 PM
