Results 1 to 5 of 5
Thread: Pictures of the Inside of a Transponder Key?
    May 2013
    Southern Maryland
    3
    Default Pictures of the Inside of a Transponder Key?
    Hi,
    I hope this counts as my second post, so I can go back and try to find the fellow who previously posted photos of the innards of a Transponder-Key.
    I have an old Mazda MPV with only one transponder key, & the dealer wants $270 for a second key, programmed. I'm planning to cut the key part off my only good key, and tape the chip-part to my steering column so I can use a plain key in the future.
    But before I cut my key up, I want to be POSITIVE that it won't disable the transponder somehow. Like, maybe the key acts as the antenna or something else which sounds equally unlikely until it's too late...
    I already tried using a "plain" ignition key while holding the Xponder key next to the ign switch, and if I hold it in the right spot it works fine. Neat-O-Matic!
    Nov 2008
    Chicago, IL
    613
    My local locksmith cut and programmed a new transponder key for me for $40. Check your local locksmith before you cut stuff up!
    1998.5 3L SVT Contour #6183/6535 - For Sale/Trade
    Oct 2008
    Dallas, Ga.
    1,723
    The transponder itself is very easy to remove. Just pop the little door open on top of the key and slide it out. At least that is how you remove it on a contour.
    -99 E1 Black/MNB #1974 stock DD
    -98 E0 Black/MNB #0812 3L sold
    -98 E0 T-Red/MNB #0322 sold
    Nov 2001
    2,880
    these are what this chip looks like thats inside the key.
    Chris
    1998 Ford SVT Contour #3571 ....... fixing and repairing daily.
    Jul 2009
    west michigan, Jenison
    537
    My local hardware (independent Do-it Best brand store) store has gotten into making keys also and guarantees they will work too. Under 100 (online at 70.00) but I havn't tried because I have a parts computer and keys if needed.
    http://www.doitbest.com/Key+blanks-H...sku-234543.dib
    mazda
    http://www.doitbest.com/Key+blanks-H...sku-234473.dib
    Now driving around in ronssvt's old car
    The rear bumper has been replaced. . . with mesh too
Similar Threads
  1. Pictures of inside a SVT trunk?
    By hallfleming in forum Pics and Videos
    Last Post: 05-18-2011, 12:54 PM
  2. RFID transponder inside the Pats key
    By F111D F in forum Duratec Maintenance
    Last Post: 01-21-2007, 10:41 PM
  3. Transponder Key Broken
    By frickfrack424 in forum Northeast
    Last Post: 12-08-2006, 11:19 PM
  4. Car Fax For Transponder Key
    By frickfrack424 in forum General Discussions
    Last Post: 11-30-2006, 01:53 PM
  5. Transponder Key Broken
    By frickfrack424 in forum General Troubleshooting
    Last Post: 11-29-2006, 12:15 AM
