blu_fuz
New Member Classroom vulture
So, we all have that quick 1 second crunch noise as the ABS system does some kind of check. It usually happens within the first 10 seconds of driving.
What would cause the crunching self check system to continually go off every 10 seconds while driving? This is happening on my '95. I can hear the system doing something, hear the crunch, and watch my lights dim and my voltage gauge drop. It does it when driving at any speed and any gear just keeps cycling.
I have no idea where to start looking to fix the issue .
I did find this quote on 'fixya' and suggested to pull the ABS fuse to confirm that it is the ABS acting up.
"Sounds like your getting abs activation when its not needed. Most likley one of the wheel speed sensors has failed. You do need to have a scan tool to read the live data from the abs module as the problem is occurring to pinpoint which sensor is faulty. The abs light will not come on because the abs module thinks its just working normally. I'm an ASE certified mechanic and have seen this problem many times on various vehicles. You might have to pay somebody to diagnose it, but replacing the sensor it a very easy task. I hope this helps."
