These are the shift cables out of my 98 SVT Contour. I put these in when I swapped over to the Focus shift tower back in 2006. The cable ends are for the ball type shift tower. You can no longer get these from Ford as the shifter cables have been discontinued. Cables and ends are in good shape. Only reason why I switched these out was because I went to a TH modified shift tower, which uses the pinned ends so these cables no longer work for me. Grab these why you can, $125 shipped to the lower 48 states.
