Results 1 to 6 of 6
Thread: 2003 Ford Taurus Heat Problems
    Nov 2011
    Rochester, MN
    40
    Default 2003 Ford Taurus Heat Problems
    I know its a contour forum but my mom drives a 2003 Ford Taurus Centennial edition and her heat has stopped working. Anyone know a common reason why this happens (Other than temperature gauge)?
    Thanks,
    Dane Austin
    Feb 2005
    Tunkhannock, PA
    1,476
    Is it still blowing air, just cool air, or not blowing at all? First thing I'd check is coolant level, is the car reaching normal operating temp? If it's not it could be a stuck open thermostat. If coolant is leaking into the cabin then it's the heater core, though it could just be plugged, but this usually arrests the flow of coolant and causes the engine to overheat.
    '99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...140K and currently dead. RIP
    '98 Dark Blue SE Sport V6 MTX 123K and counting, all mods from old, plus D2's.
    '03 5dr SVTF 110K the new DD, some mods, hoping not many more.
    Nov 2011
    Rochester, MN
    40
    Coolant is good, the car still blows air, but only cold air. It sucks because we are starting to get into this Minnesota winter haha.
    Feb 2005
    Tunkhannock, PA
    1,476
    Well how's the temp gauge reacting? If the thermostat is stuck open it will allow coolant to continually flow through the motor without heating up, leading to no heat. You'll notice the temp gauge never reaches the normal operating temp. The heater core is a very simple system, just routes hot coolant from the motor into it (it's a small radiator) and the blower motor pushes that hot air through the fins into the cabin, there's not much that could go wrong.
    Apr 2008
    Bloomington/Normal, IL
    874
    A common issue on these is the heater core clogging up. My friend had a sable close to the same year and this happened. Had it back-flushed and there was heat again. I'd start with a thermostat. If you pull it apart and the stat is stuck open, then there's a good chance you found your issue.
    -1995 Contour SE 136k Sold 7/23/09 -Christine-
    -1998 T-red SVT Contour # 5961 3L hybrid coming soon. -Miri-
    May 2011
    Cardington Ohio
    150
    The thermostat may not even be stuck open when removed, but could be weak and open prematurely. I just replaced the one in my GF's 02 buick century that was like this. Car wasnt reaching normal operating temperature so it was the first thing i dug into, car runs normal temp now and the heat is hot.
    Btw, if anyone ever wants you to change the thermostat in a GM 3100 or 3400 charge them and arm and a leg lol, they are a b-tch to get to and take about and hour and a half.
Similar Threads
  1. 2003 Ford Focus Svt
    By vaboom123 in forum Vehicles
    Last Post: 10-23-2011, 09:58 PM
  2. Heat/Cooling system problem (1996 Taurus Vulcan)
    By zorrex in forum General Troubleshooting
    Last Post: 12-26-2009, 10:26 PM
  3. Major Detail: 2003 Ford Focus ZX3
    By Dr. Cross in forum Pics and Videos
    Last Post: 07-26-2007, 08:29 PM
  4. 2.5L alternator bracket, to a 2003 3L taurus?
    By TRicker in forum Duratec 3L
    Last Post: 06-12-2007, 05:51 PM
  5. Detail of my dd: 2003 Ford Focus
    Last Post: 09-21-2006, 11:26 PM
