Results 1 to 9 of 9
Thread: rev limits
    Dec 2002
    Portland OR
    1,851
    Default rev limits
    Maybe ths belongs in the duratec tuning forum, but who's using what as their non-stock rev limits?
    And is anyone using the ST220 valve springs, and if so, with what rev limits?
    MSDS SHO-shop Y custom 2.5" catback; xcal2; 63mm TB K&N 3530 Pud heatshield; Koni struts Aussie bar; THaines forks Quaife SpecII UR fly; DMD; UD pullies; Pole120 mounts. 92.03 trap speed: Just a daily commuter. SF/MB '98 SVT E0 #3159 8/21/97 178K miles
    Sep 2002
    Fort Wayne, IN
    6,700
    7200rpms is very safe. It's also what most people are going to with the SVT cams. The power of 7200rpms isn't worth the risk in my opinion. Rod bearings are what I'd be more worried about in the upper rpms, rather than valve springs.
    Mark
    2004 Mazda 6
    Dec 2002
    Portland OR
    1,851
    I wasn't worried about the stock valve springs as much as wondering what these engines will take with stock and upgraded valve springs.
    meanwhile, with the 2.5 block, I have NO intent to do anything close to 7300 revs while doing even a mild right turn.
    The stock valvetrain can surpass 8000rpm just fine. It is not the limiting factor where rpm is considered.
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
    Sometimes it not how high the RPM's will go but were the power drops off. My car makes power up to 6800 then starts to fall off so there is no point in going beond that point.
    98 Tropic Green Contour 2.5 MTX
    May 2004
    Calgary, Alberta, Canada
    4,506
    Quote Originally Posted by MaddMike2 View Post
    I pray thats not with SVT Cams...
    Mine kept pulling all the way to redline.. I didnt move it tho as with nitrous fuel starts to become a problem..
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    Quote Originally Posted by Tourige View Post
    His signature states a regular Duratec so that (6800rpm) sounds spot on for when the stock cams are declining rapidly.
    The SVT cams will pull a fair bit past 7000rpm before they start dropping off and they trail off at a slower rate.
    2000 SVT #674
    2005 Magnum R/T
    May 2004
    4,506
    Just wanted to make sure.. He might have switched out the cams. Etc.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
  9. #9
    Not really... you stop when a shift at that point results in a new rpm value with less power than redline. With most engines and trannies, you keep revving well past max power to optimize the area under power curve, with endpoints defined by shift points. For a road course or autocross car, you want power and revs to extend out of that range as far as possible so that you can hold a gear for a little bit longer instead of shifting up, and have power down low so you can avoid an extra downshift that would put you high in the rev band.
    -Philip Maynard
    1995 V-6 5-speed parts car in great shape - PM me if you need anything.
