Results 1 to 7 of 7
Thread: Lower control arm (2 bolt) bolt shifting and making popping sound?
    Jul 2007
    Crestview, Florida
    1,805
    Default Lower control arm (2 bolt) bolt shifting and making popping sound?
    What happens is, after a right hand turn, when I brake or make a left hand turn, the back bolt of the driver side control arm shifts like less than 1 MM and makes a popping sound. As if maybe the bolt is too small? But even then, I reused the bolts that I had. I don't see how it should shift. Has anyone ever had that problem before? I was told it was a bad LCA bushing. But these are Moog control arms with like 2x,xxx miles on them. Is a bad bushing to be blamed, or what is it? And I can't remember, the driver side LCA, does the subframe lower enough to remove the bolts?
    Mikey
    1999 SVT #0604
    Jul 2007
    Middletown, Pa
    1,896
    Sounds like a bushing to me. You might need to lower the subframe/lift the trans alittle to get them out, but i'm not 100% sure on that. I've only done 4 bolt LCAs
    00 Contour SVT #1914 BLK/PT 3L Hybid, Torsen, MSDS.
    00 Contour SVT #0157 BLK/PT stripped down and parting out (15.2 @ 89, 195whp)
    95 Mystique GS:16.989@ 82.02 MPH, 38.7MPG's RIP
    Jul 2007
    Crestview, Florida
    1,805
    I hope it'll lower enough. That way I can also do my front sway delete as well. I really hope that the bushing is what it is, too.
    Mikey
    1999 SVT #0604
    Feb 2009
    Southeast Michigan
    768
    I would say its the bushing also but from my past exp you either have to cut the bolt and just replace it with another bolt but put the nut on top so next time you can just undo the bolt. I just do not personally like messing with the sub frame bolts just in case they where to strip or get damaged in any way. But again just my two sense.
    98 eo SVT Blk & MNB 2.5L built trans # 692 05/02/97(stilov's 3L Turbo)
    2000 oval-port 3L Silfro & P-Tan #1337(sold 12-28-12)
    2000 3L Blk & P-Tan #634(totaled)
    1999 Blk & P-Tan #0059(sold)
    And about 13 more :-/
    Oct 2010
    Norwich, CT
    267
    Quote Originally Posted by fogarty,john View Post
    ...you either have to cut the bolt and just replace it with another bolt but put the nut on top so next time you can just undo the bolt....
    If you didnt have to do this, than you werent the first one to do this job and its possible that you may have had the wrong bolts. They may have gone with a 3/8 instead of the correct metric size. Maybe measure just to be sure...
    Your car is uglier than I am! uh...that didnt come out right.
    Dec 2001
    Gales Ferry, CT
    24,471
    Blog Entries
    93
    its the front drivers side bolt on the control arms which could be cut, not the rear one.
    if your going to remove the sway bar just drop the subframe and do it right, put the bolt back in the correct way.
    Also the suspension bolts are not your typical off the shelf bolt either.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Jul 2007
    Crestview, Florida
    1,805
    I know, they're 10.9 grade bolts. But yeah, I'm gonna be dropping the subframe because I'm gonna do the sway delete. I thought about putting it back together, but ditched the idea.
    Mikey
    1999 SVT #0604
Similar Threads
  1. BRAND NEW FORD OEM D/S 2 bolt Control arm
    By svttour in forum Body/Suspension/Brakes
    Last Post: 04-17-2011, 10:01 PM
  2. Nut & Bolt provided with Moog Lower Control Arm??
    By primetime in forum Suspension
    Last Post: 09-14-2010, 09:29 AM
  3. 2 bolt Lower Control Arm LCA
    By muntus in forum Suspension
    Last Post: 08-12-2008, 08:26 PM
  4. 2 bolt Lower Control Arm LCA
    Last Post: 08-12-2008, 02:23 PM
  5. lower control arm pinch bolt
    By rubn3 in forum General Troubleshooting
    Last Post: 07-14-2007, 05:48 PM
