Results 1 to 7 of 7
Thread: Anyone know or able to trace this wire for me?
    Feb 2011
    Akron, Ohio
    124
    Default Anyone know or able to trace this wire for me?
    So my drivers side High Beam Light is out, i figured since the Passengers works 100% that it's probably a bad wire somewhere. Problem is the wiring is all bundled up into a giant ball of tape. I could swear someone used 25+ rolls of electrical tape. I started unwining all the wires, but after 45 minutes and not even getting 6 inches down the cluster **** I decided to jump on here really quick to ask if someone else knew where that was going so I could run a new power line.
    Note: this is a SVT 99 Contour with Bagged 3L portmatched, it also has HID low beams.
    1996 Ford Contour GL Midnight Blue 62k 2.0L Zetec Auto wrecked, front end damage. =(
    1999 Ford Contour SVT Silver 230k 3.0L MTX
    Feb 2011
    Hillsboro, MO
    341
    did you switch the driver and pass bulbs to make sure the bulb isn't just out.
    98.5 t-red Zetec mtx
    207,000 and counting
    i love bring my car into class, it give a new "special circumstance" every day.
    Feb 2011
    Akron, Ohio
    124
    Yeah, i replaced the old bulb w/ a brand new bulb. And tested both old and new they work.
    i used a multimeter n the wirings got 0 power
    Mar 2004
    Louisivlle Ky
    6,934
    did you check the fuse for the drivers side bulb? they have separate fuses for the driver and passenger side bulbs.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Feb 2011
    Akron, Ohio
    124
    Well no i Didnt check the drivers side fuse. Have to look up the diagram for the fuse box. Although would the low beam and high beam be on the same fuse for drivers side, because the low beams work great.
    Feb 2011
    Akron, Ohio
    124
    Okay check the fuse, good, double checked the new bulb, good. No power to the fuse box under the hood for that fuse.
    Anyone know if the power runs from battery to fuse to switch to light?
    Or if it runs from power to switch to fuse to light?
    Id assume the first, since it's literally right there and seems like it'd protect more that way if the switch shorts out.
    Any suggestions still greatly appreciated.
    Feb 2011
    Akron, Ohio
    124
    Upon ripping some things out of the way, it is indeed battery fuse switch light. Now time to see if I cant dismantle the fuse box....
Similar Threads
  1. Name that wire!?
    By conTourist in forum Duratec Maintenance
    Last Post: 06-06-2013, 06:06 PM
  2. Where does this wire go???
    By tophe7d in forum Duratec Maintenance
    Last Post: 08-31-2008, 11:18 PM
  3. What is this wire for?
    By European in forum General Troubleshooting
    Last Post: 05-18-2008, 10:41 PM
  4. What does this wire go to
    By rouar in forum General Troubleshooting
    Last Post: 10-25-2007, 08:27 AM
  5. What is this wire for
    By Damien in forum General Discussions
    Last Post: 10-19-2006, 07:11 PM
