Deleted ac. Now my fans run as soon as I start the car.. What should I look into? Thx guys.
98.5 svt, going back to black, and a clean engine bay and nice wheels, anyone wanna buy it in the spring?
LOCATION 55021
Might have something to do with the AC pressure switch that turns on the fans when the AC was on. One might try to jumper it or put that pressure switch back in the connector and see what happens.
AF
Proud Dad of a US Marine
99 Contour SE Sport / V6 MTX
95 Contour GL / 4banger ATX - Like no other.
"its not shot it just grinds a little when going into third" - tjzollman 2/25/08
Try to be as good a person, as your dog thinks you are....
There are also two relays in the engine compartment fuse box for the cooling fans also. Worth a check
1994 Ford Probe GT- bone stock 87k mi. future ATX-MTX
1998 Contour SVT #393- WRSW intake, custom heat shield, platinum burners, d/s rotors, tzt toe arms, poly bushings
1995 Probe GT- klze, intake, short throw. *SOLD*
I deleated all lines and everything,
Ill check the relays also.
LOCATION 55021
