Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: For those with TZT rear toe arms...
    Jun 2010
    Norfolk, VA
    437
    Default For those with TZT rear toe arms...
    How do you like them? I'd like to replace mine, and don't know if I should buy these or wait for PRT's. Have you had any trouble with rust or with the adjustment bolts seizing? Have you had any issues with the heim ends? increased noise or vibration?
    Sold- 98.5 Silver Frost #5979
    Officially a troll. 2002 Suzuka Blue Honda S2000 on Works
    Oct 2006
    Las Vegas , NV
    1,269
    All good here. I had a bent stocker, so why not upgrade.
    2000 Tropic Green SVT Contour #455 of 2150
    Born Date: Nov. 19, 1999
    Exhaust | Intake | ATS Complites | Pre-98 trunk w/ Lip Spoiler | A-pillar Gauges | Fidanza Shifter | Ground Control | Koni | Autovation | ED Splitter | Carbon Fiber EVO Hood
    ........... luuuuuuuuuuuuuv mine. My old arms weren't bent, just OEM !!
    Can't recommend enough, any mod that stiffens the rear.
    .... G.
    ST24. LPG, ST200 cam's, RLJ1 PCM, 19lb injectors, 65mm P&P'd TB, headers, lowered, sway bars and strut braces, 300/278mm brakes, 3.51 FD tranny, Torsen, Fidanza.... Vortech in progress .
    WANTED; RLJ1 with static 2.5L Vortec settings.
    Dec 2005
    formerly las vegas, now dallas TX
    3,514
    Quote Originally Posted by gorman View Post
    .... G.
    The rear can be over stiffened, right? In other words, its not necessarily good if theres too much grip in the rear, especially compared to the front?
    Julian
    98.5 csvt #6226 of 6535
    Rally Inspired 3L turbo'd monsTOUR
    Modifications??? well...lets just say this ain'tcha grandma's contour
    Quote Originally Posted by BAD SVT View Post
    true; but i don't think these mods are going to go too far grip wise.
    I found my toe arms/strut brace/sway bar combo. stopped the back end of the car from rolling around in corners and gave firm feedback and support that you can feel thru the seat of your pants.
    Is your car nicely balanced ? .... G.
    Dec 2005
    3,514
    I think so. The only suspension mod i've got is an aussie 24mm swaybar in the rear. Ground control coilovers & koni struts all around. Everything else is stock. I was never really sure if it'd be too much if i modded anything else...
    Julian
    These mod's are more concerned with removing unwanted slop and play which can unsettle your car. I believe you could do more harm if your springs and dampers were too stiff.
    Bottom line; you want flex... but it must be predictable/controlled.
    Aussie 24mm; mmmm, always wondered what that would be like. ... G.
    Dec 2005
    3,514
    ...Aussie 24mm; mmmm, always wondered what that would be like. ... G.
    Pretty cool i think. Grip & handling is very good. I guess it couldnt hurt to add the tzt toe arms...
    Julian
  9. #9
    the stockies truely are crap...... G.
  10. #10
    Dec 2005
    3,514
    Gotcha. Then again, i've needed new rear endlinks for a while now. So i might consider picking these up. They come with endlinks, right?
    Julian
Page 1 of 2
1 2 LastLast
Similar Threads
  1. GB: TZT Performance rear toe arms
    By striker2 in forum Group Buy
    Last Post: 08-15-2011, 01:45 PM
  2. MASSIVE tubular rear toe arms - AVAILABLE SOON.
    By B3NN3TT in forum Suspension
    Last Post: 08-08-2011, 11:38 PM
  3. massive rear toe/ control arms
    By 98redcoupe in forum Suspension
    Last Post: 06-29-2011, 04:39 PM
  4. TZT Performance Rear Toe Arms
    Last Post: 05-23-2011, 10:05 PM
  5. tubular rear toe arms: poly heim joint?
    By flyguyeddy in forum Suspension
    Last Post: 08-12-2008, 08:35 PM
