I have a 4ch precision power amp for sale....PC4800. I was going to keep it and use it but I need other things more than a nice amp. This amp does work and is a beast. It was one of the last few good amps that precision power made before they switched to the crap they make now. It is painted yellow but can easily be repainted a different color. This thing new listed for $1200 back in the day...not sure if it was 2000 or 2001. I have it listed on craigslist for $250 for I will sell it to a fellow ceger for $150. Here are the specs and a few pics:
Power Bandwidth: 4.5 Hz - 100 kHz
Total Harmonic Distortion: 0.02 %
Input Topology: Differential
Input Sensitivity: 150mv - 12 volts RMS
Input Impedance: 10k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridge) 4 - 8 Ohms
Supply Voltage 11 - 15 volts
Damping Factor >500
Slew Rate >50 V/mS
Idle Current: PC4800.2 - 3.0 Amps
100 WRMS x 4 @ 4 Ohms per channel
200 WRMS x 4 @ 2 Ohms per channel
400 WRMS x 2 @ 4 Ohms bridged
Front - 12dB/Octave, Detented High Pass 20-5kHz
Rear - Choice of 12dB/Octave Detented High Pass 20-5kHz, or
Summed Mono 24dB/Octave, Linkwitz-Riley Detented Low Pass 44-315Hz
RCA Outputs will be the opposite of your Rear Crossover choice.
QBASS PLUS***8482; on Rear Channel
Demensions:
Length - 23.72"
Height - 2.25"
Width - 8.9"
Max fuse rating: 80 Amp
http://s926.photobucket.com/albums/a...5-07153919.jpg
http://s926.photobucket.com/albums/a...5-07153858.jpg
http://s926.photobucket.com/albums/a...5-07153849.jpg
