Results 1 to 2 of 2
Thread: Motor Mount / Roll Restrictor?
    Nov 2009
    Maspeth NY
    30
    Default Motor Mount / Roll Restrictor?
    Hi guys
    I need some help. Im trying to get my car inspected but im told i need a gas cap and a front motor mount (right under/behind the radiator on the subframe) (from what i learned from searching this is called a roll restrictor?) What i would like to do since its cheaper and i cant find the part anywhere is go to a slavage yard and pick one.
    My questions are:
    - is this part available anywhere?
    - will the part be the same for an at and a mt?
    -1995 zetec mtx75
    Oct 2007
    Moreno Valley, California
    204
    If you have an O'Reilly's near you, you can get the insert for $15.00. I did this for my '96 Contour. Very cheap. Here's the link.
    http://www.oreillyauto.com/site/c/de...2327&ppt=C0019
    1996 Ford Contour Sport
    2.0L
    Zetec (170,000 mi.) / 5-speed MTX / 2.25" exhaust upgrade w/ Weapon-R header
    Ford 3G 200-amp Alternator /
    Optima Deep Cycle Battery (yellow top)
    Custom 10-speaker, 3-amplifier sound system
Similar Threads
  1. Replies: 2
    Last Post: 02-07-2012, 08:38 PM
  2. roll restrictor
    By cetroutt in forum General Troubleshooting
    Last Post: 07-31-2011, 12:58 PM
  3. Another roll restrictor question
    By Cobra99 in forum Duratec Maintenance
    Last Post: 01-15-2009, 05:17 PM
  4. How to: Replace FRONT Roll Resistor (motor mount)??
    By Lanky R in forum Duratec Maintenance
    Last Post: 09-29-2008, 10:47 AM
  5. Trans Mount or Roll restrictor?
    By milleniahead in forum Duratec Maintenance
    Last Post: 07-15-2008, 08:02 AM
