Results 1 to 2 of 2
Thread: 1998 Contour SVT 5292
    Nov 2009
    cleveland ohio
    172
    Default 1998 Contour SVT 5292
    Number 5292 has been my baby now for the last year and it is simply time for me to move on to a different platform. I have not locally listed the car yet. I would like the car to go to a fellow ceg'er.
    Engine
    Ported 3l to match the svt upper and lower intake
    2.5 oil pan and pick up
    Stock tune.
    Clutch Oem replacement with lifetime warranty
    I have put 22 thousand miles on the engine and clutch since the swap. The motor was purchased with 29 thousand miles. Bringing it to 51 thousand miles as it sits today. The motor always received mobile 1 full synthetic with K&N oil filer every 3 thousand miles.
    New power steering pump - with life time warranty
    New ac compressor.
    Transmission:
    Stock
    Was told it was rebuilt under at a ford dealer before I purchased the car but I do not have any sort of paper work to prove this.
    New transmission cables
    Suspension:
    Intrax springs
    Monrow strusts
    New control arms- with life time warranty
    New tie rods
    New rear control arm bushings
    New strut mount bearing plates
    PRT rear sway bar connectors
    Duralast sway bar connectors in the front
    All new wheel bearings
    Brakes:
    Oem replacement calipers all the way around
    Duralast Gold C'max in the front
    Oem rotors
    Oem pads in the rear
    Oem replacement e-brake cables
    Stainless brake hoses
    Exhaust:
    Stock with resonator delete
    Interior:
    Stock, nothing special
    I would give it a 8 out of 10. No dash warp or rips.
    Exterior:
    Custom sky metallic Blue. I have the paint code along with the ordinal paint that the car was painted with. The car was completely striped to be painted jams, doors, ect…
    Custom front splitter and mounting brackets.
    Molded jack point covers.
    17inch rage rims with Hancook tires, comes complete with a bend in each rim. The tires are showing inner camber wear. Nothing horrible but I would recommend replacing them.
    Carbon fiber trunk.
    The car sits with 155 thousand miles. I consider the car to be super clean. It does have some surface rust on the underside, nothing major. It is a typical north east Ohio garage kept car. The Abs light is on; it needs 3 new sensors.
    I am asking 6000 for the car but am open to offers and/or trades. The worst I can say is no. I am looking for another car rwd. In particular Rx7's and Bmw's
    Thank you for looking!
    Sometimes you just have to remember it is your life
    Nov 2009
    cleveland ohio
    172
Similar Threads
  1. Replies: 14
    Last Post: 05-06-2012, 09:40 PM
  2. 1998 SVT Contour
    By newb in forum Vehicles
    Last Post: 12-03-2011, 11:54 AM
  3. 1998 contour svt 3.0
    By rob131 in forum Vehicles
    Last Post: 11-05-2011, 02:29 PM
  4. 1998 Svt Contour
    By svtnoodle in forum Vehicles
    Last Post: 05-19-2011, 06:59 PM
  5. 1998 contour svt
    By derekvivera in forum New Member Classroom
    Last Post: 05-15-2010, 09:08 AM
