For sale is a black svt. 144k 2nd owner. diablo chip short shifter. having trans issues......
The good:
I was in the process of overhauling the entier suspension.... so the car has brand new d2 coilovers on the front (didnt get to the rear yet becasue of the trans issuses) along with new control arms. inner and out tie rod ends. upgraded front sway bar links and goorich braided brake lines and new wheel bearings. I also have the upgrades as well for the rear from the same group by. i also have all of the stock suspension parts/sturts springs ect. also for sale with the car is a brand new msds y-pipe and nautalis intake. i have the factory e1 wheels and svt center caps with tires that are less that a year old including the 18s that are on the car curretly. i cracked one of the factory headlights and ordered a set so those will come with the car too. the car starts up just fine but is sadly cant drive becasue of the trans. oh and to top it all off i have a mirko splitter. a real one. still in primer thats going with the car also. Im asking 3000 obo. but if someone can give me a decent offer they can come and get it.
...now the bad:
About six month ago the passenger side tie rod broke causing me to steer into a parked car. As a result of that the passenger front fender needs to be replaced. The brake line that goes to the passenger side was also bent and needs to be replaced. The front caliper bleed screw also snapped off and needs to be drilled out. The biggest problem is that while installing the new suspension. I started the car and went to move it. When i let out the clutch the car began to move but the rear parking brake was stuck causing something in the trans to give out. car starts and runs fine.....but at the same time can be shifted for gear to gear with no clutch. could be the clutch. more likely its the diff. but at any rate im not up to deal with it.
Bottom line the trans needs to come out and i dont have the time to play with it....ive got a datsun and a v8 that im trying to bring together right now.....so pm with an offer. i am 15 from dc. in northern va. haller. thanks.
