Results 1 to 4 of 4
Thread: 6 Speed Getreg swap???
    Mar 2012
    Whitewater
    11
    Default 6 Speed Getreg swap???
    I'm looking to find out if anyone has done/seen/heard of a swap in a Contour, from the MTX-75 to the 6 speed SVT Focus transmission.
    I work at a dealership where I also plan to have work done on my CSVT. Talking with the mechanics, the "SVT guy" isn't sure that its possible because of the lack of space, which makes sense, but I'd like to find out for sure.
    I'll be doing a swap or rebuild on my CSVT sometime, and my current MTX needs some work as well.
    Seeing as the MTX matches up with all the Duratec's, would the Getreg bolt up to a 2.5 or 3L?
    If I could, I'd love to drop a 6 speed in there.
    Who knows though, I wont keep my hopes up.
    It'd be great if anyone could shed some light on the idea.
    Thanks!
    Feb 2005
    Tunkhannock, PA
    1,405
    If you had searched you would know this comes up a lot and the consensus is the SVTF 6-speed is much weaker than the MTX-75, in addition, the zetec MTX-75 is different from the duratec model and is not a straight swap even between Contours, imagine the difference between a Focus on a totally different transaxle.
    Short version, while technically you could there's absolutely no reason too, in the end you'll spend more money and have a weaker trans.
    '99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...140K and currently dead. RIP
    '98 Dark Blue SE Sport V6 MTX 123K and counting, all mods from old, plus D2's.
    Out with the old, in with the....slightly older...?
    Dec 2008
    Brick, NJ
    735
    That and simply having a 6 speed does not automatically make it better than having a 5 speed. There are a LOT of people, good example is the AutoX world who would rather have the 5 speed for the wider gear ratios. Many times the 6 speed and 5 speed final drive is the same between models, the 6 speed simply has an extra gear somewhere between 1 and 2 or 2 and 3 or whatever.
    -00' Contour SVT #1245 of 2150. Trubendz Borla exhaust, BAT Catted Y, Spec shifter, Injen CAI, NPG Big Brakes, Modded Sunroof.
    -98' Mustang GT. PI Engine, exhaust, Cobra front bumper/R hood, 3.73s, deep dish Bullitt rims, lowered, lots of other stuff.
    Jul 2009
    Bangor, Maine
    1,312
    Some of the Noble guys are swapping out their 6-speed units for a built version of the HMS MTX-75. Mostly because the MTX-75 can take make much more power than the 6-speed if built properly.
    2001 SVT Lightning #2839 - Stock
    2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
Similar Threads
  1. ST220 6 speed swap
    By HotRodV6 in forum Transaxle
    Last Post: 03-27-2012, 12:05 AM
  2. MPV 3.0L Swap?? Can i use the MPV 5 speed Auto?
    By HotRodV6 in forum Duratec 3L
    Last Post: 07-03-2011, 10:16 PM
  3. 5 speed swap?
    By mrlee5353 in forum General Discussions
    Last Post: 04-02-2009, 01:21 AM
  4. 3L Short Block Swap - Total Swap Cost
    By Bourne in forum New Member Classroom
    Last Post: 12-24-2007, 10:07 PM
  5. 5 speed swap
    By smokedya95stang in forum Transaxle
    Last Post: 01-09-2007, 08:23 AM
