tune will get you more hp then any of those
1999 Mercury Cougar Full 3.0L MTX
199 HP, 195 TQ
Yes, you're referring to the 96-99 Duratecs, but correct me if I'm wrong they aren't compatible with an E1 injector harness. I'm sure it could be modified to work though.
Actually if done properly, 2.5L head > 3L head. However most don't have the money necessary to properly build a hybrid. You need to port the SVT intake manifolds, and port the head to match the larger IMs and to accept 3L valves. The higher compression with a proper tune will result in more power.
Sold- 98.5 Silver Frost #5979
Officially a troll. 2002 Suzuka Blue Honda S2000 on Works
A few things done on my car, some more subtle than others
The obvious
1) Sparco seats- much lighter than stock
2) Cf hood
Not so obvious:
deleted windshield washer reservoir
deleted center belt assembly (who sits there anyways?
IMRC/secondaries deleted
lighter wheels
lighter brakes
lighter exhaust
no spare/jack
skinny driver mod lol
Other things I'm considering:
AC delete
EGR delete
CF trunk
sunroof delete
aftermarket steering wheel/airbag delete
You want to consider weight distribution as well. For drag racing, you want to keep as much weight over the front wheels as possible for maximum traction. Things like stiffer motor mounts and stiffer springs will help minimize wheel hop and weight transfer. Sticky tires and an LSD (well technically an ATB) will go a long way as well.
Headers don't make that much of a difference on these cars sound wise. At least in my opinion. But they do make a very good gain in HP.
2011 Fusion SE V6 & 07 Honda Pilot EX-L
98 3.0L SVT Sold 9-11-11
99 3.0L SVT Silver Frost #1264 Sold 1-22-10
95 SE MTX---Sold 9/14/07 sniff
98 E1 SVT #4892 of 6535T-Red Sold 8-29-08
Nitrous Oxide?
2001 SVT Lightning #2839 - | Pulley | Tune | Bolt-ons |
2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
Yep, I wasn't sure of the exact year-range. I'm not 100% sure but I think they did have the uscar (EV6) style connector. I ran into this issue with finding injectors for the Cougar, I needed larger injectors with a narrow spray pattern and a uscar connector. I couldn't find them so I ended up going with a jetronic/minitmer (EV1) connector and will end up splicing the harness or repinning the connectors if I can. The E1 (returnless) harness uses the EV6 or USCAR connectors and the E0 (return) uses EV1 or jetronic/minitmer connectors.
You can definitely improve the 60' times and with some practice I'm sure you could get down to a 2.1 or even a 2.2 60' which would get you into the 14's. That is something you'll want to work on, it's not easy to launch a 3L Contour though, too much throttle or too fast off the clutch and you just shred the tires, too little and you run slow or bog. You want to be accelerating at the verge of spinning the tires. Does it have SVT cams? If so, you definitely want to bring 1st gear right up to redline if not close to bouncing it off the rev limiter. That'll help your time some as well too.
One of my good friends had a 3L hybrid is his SVT with stock headers, CC CAI, bat y-pipe, borla catback and he consistently ran in the 14.4-14.6 range. That did have 3L valves in the heads but it also had a full stereo with 2 12's in the trunk so it was no lightweight either. Actually, I have the heads in my basement now!
Like everyone has said a tune will definitely help you but make sure you get it running 100% correctly before going to a tune. If you tune a car with issues and then fix the issues you'll need to retune it as I'm sure you know. I would verify that your IMRC is ok, maybe test with another known good one or just swap it out with another one and see what happens.
02 Cougar Sport - Vortech Supercharged - 13's or Nitrous!
07 Focus SE ZX3 - FRPP Suspension/Gunmetal E1's/AVIC Navigation/Hitch - The DD
97 F150 - Toy Hauler
Mr. Spindlelegs
1999 Black SVT #1658 of 2760
2004 Volkwagen Golf TDI
You might be right about that, but from what I've gathered Ford switching from the split port design to oval port V6's is widely considered a cost saving measure, not a performance one.
Consider this: a full 3L from the factory comes with 200bhp. However, an SVT 2.5L also comes with 200bhp. Why? The cylinder heads and the intake manifolds. The greatest restriction on a 2.5 head are the valves, porting the head for 3L valves takes care of that.
Of course then you get into the argument of low rpm torque vs. peak power at high rpms, but that's just going to give everyone a headache.
A large part of the SVTs power comes from the tune. Thats why its recommended to run 92 octane. The SVT engine doesnt have any higher compression than a standard 3L which runs on 87 octane.
TZT Performance http://www.tztperformance.com/
officially a troll. '93 3000GT VR4 #2229/2595
'00 Black SVTC #391 - sold 5/1/10
'97 GL Turbo Zetec - gone
Well true...but it needed to be retuned to compensate for the increased air volume in the combustion chamber. The 2000 SVT did have a slightly higher compression ratio...The 3L duratec was 10.0:1 while the SVT was 10.25:1. Of course if you put the SVT head on the 3L you bump up the CR to 11.25:1 and happy things occur....with a tune
