Page 1 of 4
1 2 3 ... LastLast
Results 1 to 10 of 33
Thread: Need more power!
    Jul 2007
    Middletown, Pa
    1,896
    Default Need more power!
    So, i went to the drag strip this weekend and i'm not happy enough. Best time was a 15.282 @ 89.92 mph.
    My mod list includes:
    03 Ford Escape 3L
    02 Cougar heads
    AEM short ram
    MSDS Y pipe
    19lb injectors
    Optimized TB
    Gutted main cat
    I'm wondering, what else should i do for more power? Would i get more out of a Tune or headers? I dont want to go crazy on the exhaust though, i like my car being quiet, but i want to hit 14's. I'm also running stock weight. Is there much i can do to reduce weight without making the car look like my Mystique (gutted)
    00 Contour SVT #1914 BLK/PT 3L Hybid, Torsen, MSDS.
    00 Contour SVT #0157 BLK/PT stripped down and parting out (15.2 @ 89, 195whp)
    95 Mystique GS:16.989@ 82.02 MPH, 38.7MPG's RIP
    Dec 2010
    Denver, CO
    469
    I personally loooove headers, they will give you some power but without a main cat your exhaust will be pretty loud.
    -2011 Silverado -98 CSVT #2358
    -02 Coug: Full 3L, ST220, 65mm, Longtubes, HMS, Quaife, Fidanza, Clutchnet 6 puck, DSS axles, Koni/GC, Aussie RSB, TZT links, Stangkillers, Pro race 1.2, Wilwood 13"F 11.75"R BBK, CF hood & hatch, 8pt roll bar
    Mar 2004
    Louisivlle Ky
    6,934
    I would do headers, 24# injectors, and a tune.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Mar 2003
    oneonta ny
    4,857
    Blog Entries
    1
    Quote Originally Posted by striker2 View Post
    this, with a full exhaust.
    --current cars: 1998 contour svt # 0165, 2009 mercury mariner premiere
    --past cars: 1996 contour se, too many mods to list!!, 1999 silfro svt, 1999 tropic green svt, and tooooooooo many others to list.
    Jul 2007
    Middletown, Pa
    1,896
    Quote Originally Posted by troll96se View Post
    Read above. I dont want my car to be loud. But yea, headers and a tune would help a lot I'm sure.
    Sep 2010
    La Mirada, CA
    321
    On my 3L the thing that added the most power out of intake, decat, catback and headers/y pipe was the headers and y pipe. I think it would probably give you some good gains. Although im untuned on my portmatched setup so not sure what will give more
    2000 Silver Frost- 1349
    3L Portmatched-SVT Cams-NPG CAI-65MM TB-Weapon R Headers-Weapon R Y Pipe--Trubendz Decat Pipe/Flex Pipe-2.5 Trubendz Custom Catback
    Jun 2010
    Norfolk, VA
    433
    This. But aren't all 24lb injects meant for oval ports? He has a hybrid
    Sold- 98.5 Silver Frost #5979
    Officially a troll. 2002 Suzuka Blue Honda S2000 on Works
    Aug 2003
    Penfield, NY
    2,676
    Quote Originally Posted by YOOOO View Post
    Nope, grab a set out of an 'older' taurus 3L with split port intakes/heads. Actually, thinking about it I may have a set in one of my parts bins, I'd have to check.
    EDIT: I think I saw in your other thread you were having IMRC issues as well. I'd get that straightened out and get back to the track, you should definitely be well into the 14's on a Hybrid 3L... For reference I ran a 15.2 @ 91 or 92mph on a 2.5L with all the bolt-ons and a tune so high 14's should be easily doable. How was the track prepped? Problems getting the car to hook up? What was your 60' time?
    02 Cougar Sport - Vortech Supercharged - 13's or Nitrous!
    07 Focus SE ZX3 - FRPP Suspension/Gunmetal E1's/AVIC Navigation/Hitch - The DD
    97 F150 - Toy Hauler
  9. #9
    Jun 2003
    Parts Unknown, Weight Unknown
    466
    Quote Originally Posted by 95_Mystique View Post
    03 Ford Escape 3L
    02 Cougar heads
    AEM short ram
    MSDS Y pipe
    19lb injectors
    Optimized TB
    Gutted main cat
    Well, you do need to do the following:
    Headers
    Larger exhaust - need bigger id going from the catalytic converter back to where the exhaust splits into the quasi-dual set-up. The stock resonator is a serious restriction.
    Get the motor tuned
    However, you need to address another restriction that nobody has pointed out: the cylinder heads. Why did you put 2.5L cylinder heads on a 3L block? The valves are bigger on the 3L heads:
    2002 Cougar 2.5L Intake Valve = 1.26"
    2002 Cougar 2.5 L Exhaust Valve = 1.023"
    2003 Escape 3.0L Intake Valve = 1.378"
    2003 Escape 3.0L Exhaust Valve = 1.181"
    Get the right heads on your car to get the motor to breathe, add headers, address the exhaust restriction and then get a tune. You may or may not need to go with larger injectors. Some people do fine with the 19 lb injectors but the 3.0L technically needs larger (24 lb).
    Mr. Spindlelegs
    1999 Black SVT #1658 of 2760
    2004 Volkwagen Golf TDI
  10. #10
    Jul 2007
    Middletown, Pa
    1,896
    Quote Originally Posted by 99Mystique ATX View Post
    I'm not sure, but i'm thinking the IMRC was getting too hot and causing the secondaries to not stay open the whole time. I could feel the car kinda hesitating on the top end, like it wasnt getting enough air. When i popped the hood, the IMRC was almost too hot to touch, would that cause an issue?
    I was averaging between a 2.3 and a 2.4 60', and that was pretty much rolling out of the hole (watch this video)
    http://www.youtube.com/watch?v=VoOrp...09AUAAAAAAADAA
    Quote Originally Posted by mrspindlelegs View Post
    Headers
    Get the motor tuned
    I didnt build this motor, the car was bought with it. I'm not going to address the heads until i have to pull the motor again (just had it out for a trans replacement 3 weeks ago). As for the exhaust and tune, i guess those will be a couple of the first things on my list.
Page 1 of 4
1 2 3 ... LastLast
Similar Threads
  1. Fluttering Power, inconsistent power across powerband.
    By Danno-23 in forum General Troubleshooting
    Last Post: 07-04-2011, 12:43 AM
  2. NEED More Power 99 SE
    By BoOgIeMaN_SE in forum Duratec Performance
    Last Post: 04-27-2011, 10:29 AM
  3. need more POWER
    By 2.5ppower in forum New Member Classroom
    Last Post: 11-10-2010, 01:42 PM
  4. Power window auto power down relay
    By undeadmechanic in forum General Discussions
    Last Post: 09-28-2010, 10:21 PM
  5. I have the power!
    By Ray in forum South Central
    Last Post: 09-06-2006, 12:15 PM
