Results 1 to 3 of 3
Thread: Main vacuum line disconnect help
    Default Main vacuum line disconnect help
    I need to remove my upper intake plenum. How do you remove the vacuum lines for the brake booster and the main vacuum source for the engine? Those 2 plastic lines that connect to the upper intake plenum.
    It says to depress the black retainer to disconnect. I just don't want to break them.
    Can anyone help?
    #436 04/97 E0
    Dec 2001
    Gales Ferry, CT
    24,502
    Blog Entries
    93
    you press the vacuum line into the UIM. then with a pick ora flat blade screw driver hold down the plastic collar and pull the vacuum line up.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Hey thanks alot for the quick response. Really helpful.
    #436 04/97 E0
Similar Threads
  1. Fuel Line Disconnect
    By CodyTRX in forum Duratec Maintenance
    Last Post: 04-07-2012, 05:32 PM
  2. Vacuum line location
    By hoveyh in forum General Troubleshooting
    Last Post: 08-13-2007, 09:57 PM
  3. Where The ???? Is That Vacuum Line
    By scavenger in forum General Troubleshooting
    Last Post: 07-14-2007, 03:33 AM
  4. where does this vacuum line go??????
    Last Post: 07-12-2007, 11:42 PM
  5. where's this vacuum line go
    By foamerdave in forum General Troubleshooting
    Last Post: 12-10-2006, 11:20 PM
