I need to remove the crankshaft harmonic damper from my 98 2.5L duratec. How do you hold the pulley in place to loosen the 18mm crank bolt? The only way I see possible is to remove the starter motor and jam the flywheel teeth with a prybar.
How do you hold the crank pulley while loosening the crank pulley bolt?
