Results 1 to 5 of 5
Thread: eBay y-pipe with cat by Mandrel Exhaust Systems -- any experience?
    Default eBay y-pipe with cat by Mandrel Exhaust Systems -- any experience?
    I need to get a new Y-pipe, and the honeycomb on my cat is knocking around.. so I probably should replace the cat at the same time.
    I found a decent-looking Y-pipe setup on eBay, which comes with a magnaflow cat :: http://www.ebay.com/itm/95-02-COUGAR...9#ht_819wt_905 . Has anyone had any experience with these? Do the bends / size seem to be decent enough?
    Thanks!
    Mar 2003
    oneonta ny
    4,857
    Blog Entries
    1
    its a performance ypipe made by TRUBENDZ Yes there are prob thousands of people who have used their products.
    --current cars: 1998 contour svt # 0165, 2009 mercury mariner premiere
    --past cars: 1996 contour se, too many mods to list!!, 1999 silfro svt, 1999 tropic green svt, and tooooooooo many others to list.
    Jan 2006
    Chicago Area
    204
    They make the system with both mild steel and stainless steel. Get the stainless!
    '00' SVT Contour
    '87' VW ITA 16V Scirocco race car
    "Drag racing is for those drivers who can't brake and downshift at the same time."
    Dec 2002
    Portland OR
    1,986
    So that seller wanted $310 plus shipping. It looks to NOT have the horrible bend that the MSDS y pipe had, but then look at how the two pipes from the manifolds get crowded into a single inlet going into that flex pipe and cat. Did you look at the two inlet one outlet y pipe cat combo that British American Transfer still sells for listed price under $380? NO horrible bends, no crowded crush of pipes similar to the stock y pipe, and the cat is a 2.5" outlet. Really, a good flowing y pipe is worth a few horsepower by itself, and it helps compound the benefits of other mods. Yes, this is a pet topic of mine. The only way to do better than this BAT y pipe that I've seen is going true duals.
    MSDS, SHO-shop Y, 2.5" catback; xcal2; 63mm TB, K&N 3530, pud heatshield; Koni struts, Aussie bar; THMS forks, Quaife; DMD; UD pullies; 94A poly mnts. 92.03 trap speed: daily driver. SF/MB '98 SVT E0 #3159 8/21/97 218K miles. Looking for A/C
    Jul 2009
    Bangor, Maine
    1,312
    Quote Originally Posted by PDXSVT View Post
    I have a two inlet, one outlet y-pipe on my SVT. Picture whore time!
    2001 SVT Lightning #2839 - Stock
    2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
Similar Threads
  1. All new. Y-pipe, motor mount, cat with pipe, and intake misc.
    By Nicelycontoured in forum Performance
    Last Post: 07-10-2012, 01:27 AM
  2. 2 Svt cat back exhaust systems in Michigan
    By Detailed in forum Performance
    Last Post: 03-07-2012, 07:51 AM
  3. FS: MSDS Y-pipe/hi-flow cat/flex pipe
    By SVT Doood in forum Performance
    Last Post: 11-12-2011, 01:31 PM
  4. Exhaust Systems With Mufflers At The End
    By rexxdoggy in forum Exhaust
    Last Post: 11-23-2007, 11:33 AM
  5. TruBendz Dual Exhaust Systems on Sale NOW!
    By BrApple in forum Duratec Performance
    Last Post: 10-27-2007, 09:03 AM
