Page 1 of 2
1 2 LastLast
Results 1 to 10 of 19
Thread: MTX 75 Removal and tips
    Dec 2011
    Allentown, PA & Newport News, VA too :)
    87
    Default MTX 75 Removal and tips
    Hello everyone,
    I am pulling my transmission from the underside of my 1998.5 Contour SVT totake care of a couple of things that include replacing my clutch, pressureplate, flywheel, and my rear main seal on my engine. I’m now creating a list of things I must doto do this properly and safely. I haveread other threads, posts, and even other forums on how to do this type ofprocedure and decided to compile them here (there is a lot of differentiatingopinions out there lol). I only want tohave to do what is necessary for my circumstances and do not want to do moresteps or mess with other systems unless necessary. Hopefully those of you with more experiencecan help me out with this and also do it safely. My goal is to lower the subframe on the driver’sside but loosen it on the passenger side so I don’t have to drop the wholething and just remove the tranny through the driver side wheel well. Also, while I do this, would anyone beinterested in if I made a video on how I did this to help others and also forfuture reference??
    Ok here we go
    1. Jack car off ground using four or more jack stands
    2. remove front bumper and side skirts for more clearanceand less height to jack car
    3. drain oil overnight
    4. drain transaxle fluid overnight
    5. drain power steering resv overnight
    6. Remove battery and battery tray
    7. undo suspension strut nut 5 turns on both sides
    8. secure radiator from top
    9. remove air cleaner
    10. removewater pump cover
    11. disconnectaccelerator and speed control cables
    12. disconnectground cable
    13. disconnectpwr steering res hose
    14. disconnectVSS
    15. disconnectfuel lines
    16. disconnectstarter motor electrical connectors
    17. removerair cleaner bracket and starter motor bracket
    18. Removeclutch slave cylinder hydraulic pipe (Do I have to drain brake fluidovernight??)
    19. removestarter motor
    20. supportsubframe and engine from underside using hydraulic floor jacks and lumber andjack stands
    21. removeleft transaxle support insulator and studs
    22. removefour upper bell housing bolts
    23. removefront wheels
    24. removesplash shields
    25. disconnectlower suspension arm from wheel knuckle and wiring harness bracket
    26. removeright hand half shaft and intermediate shaft and secure out of the way
    27. removeleft hand half shaft and secure
    28. removeradiator splash shield
    29. removey pipe
    30. remove2ndary 3way cat conv
    31. removeradiator support brackets
    32. removeand reposition bumper bracket
    33. removesuction accumulator
    34. removeheated oxygen sensor
    35. removeintermediate shaft pinch bolt
    36. removefront roll restrictor
    37. removerear roll restrictor
    38. loosenpassenger side subframe bolts, remove driver side bolts
    39. disconnectshifter cable brackets
    40. removepower steering line bracket
    41. supporttranny
    42. removelower bell housing bolts
    43. removelower front bell housing bolt and nut
    44. removetranny
    Installation is reverse of removal, but also what kind of sealers andcompounds should I use when putting the various parts back together. Hopefully you all can help.
    Thanks in advance.
    " Stallion" ---1998.5 Ford Contour SVT Black/Midnight Blue
    Quote Originally Posted by r_dsn View Post
    It works on a plasma based osmosis filter that probably has a little fairy dust mixed in because this thing removes beer from the blood like no other!
    Dec 2011
    87
    Sorry my copy/paste from word left no spaces sometimes...
    Apr 2010
    Louisville, KY
    114
    2. Remove wheels
    remove front bumper and side skirts for more clearance and less height to jack car (not needed)
    1. drain oil overnight
    2. drain transaxle fluid overnight
    3. drain power steering resv overnight
    4. Remove battery and battery tray (I didn’t but if it makes things easier for you)
    5. undo suspension strut nut 5 turns on both sides (only driverside needed)
    6. secure radiator from top
    7. remove air cleaner
      removal of water pump cover (not needed)
    8. disconnect accelerator and speed control cables
    9. disconnect pwr steering res hose and cooler hose from the rack and the 2 line brackets from the subframe
    10. disconnect VSS and other transmission plugs located near the shift tower
    disconnection of the fuel lines (not needed)
    1. disconnect starter motor electrical connectors
    2. Removeclutch slave cylinder hydraulic pipe (Do I have to drain brake fluidovernight?? No. Very little will actually come out and the brakes and clutch fluids are divided at a certain point so the level will only drop a little and bleeding the brakes will not be needed)
    3. remove starter motor (this is optional)
    4. remove splash shields
    5. disconnect lower suspension arm from wheel knuckle and wiring harness bracket
    6. remove right hand axle half shaft and intermediate shaft and secure out of the way
    7. remove left hand axle half shaft and secure
    8. remove y pipe with o2 sensor
    9. remove secondary cat and mid pipe or support
    remove radiator support brackets (not needed)
    remove and reposition bumper bracket (not needed)
    remove suction accumulator (The what?)
    1. remove intermediate shaft pinch bolt inside the car
    2. remove front roll restrictor
    3. remove rear roll restrictor
    4. disconnect shifter cable brackets or entire shift tower
    5. Support the engine and transaxle with jacks and wood or support on the engine from above
    6. Loosen the passenger side motor mount bolt as you may need to let the engine sag a bit
    7. loosen passenger side subframe bolts, remove driver side bolts ( I just dropped out the whole subframe. It wasn’t that difficult to get back but will need two people or some creative jack work)
    8. remove upper transaxle mount
    9. remove bell housing bolts
    10. wiggle that puppy out
    98 T-Red CSVT #5351/6535
    CAI, Bat Euro Handling Kit, MSDS headers & y-pipe, Borla cat-back, Torsen LSD, B&M short shifter
    Sep 2008
    Charlotte, NC
    416
    IMO its much easier/simpler to pull the engine and tranny out as one and then separate and replace whatever you want, bolt together and put back in.
    Pearl Black 98 CSVT- Konis GC l OZ Supperleggeras l B&M l Port-Matched 3l SVT Cams w/gutted SVT LIM l EH SVT UIM l 65mm TB l NPG CAI l COPs l Black Hightowers w/projectors l Pre98 l Freedom Design FSTB l RSTB l
    2kBlack/Tan CSVT 77k Restore
    3 CSVT Sold
    Dec 2011
    87
    so when you lower the subframe completly, the engine and transmission come down attached to and supported by the subframe or are the engine/tranny seperate from the subframe?
    Jul 2007
    Crestview, Florida
    1,808
    The engine and transmission is attached to the subframe via the roll restrictors in both the front and rear part of the subframe.
    Mikey
    1999 SVT #0604
    Mar 2003
    Hamilton, ON
    1,254
    its honestly easier to pull motor/trans together thru the top
    SOLD ---- Sean - 1998.5 3.0L CSVT #5906 - "MONSTOUR"
    Quote Originally Posted by rexxdoggy
    My intake right now is a heat soak muh fuh'in short ram gayness.
    Jan 2006
    Montreal
    949
    I just created a thread for this last week (linky).
    I would be very interested in pics etc if you can do it.
    00 Silver Frost SVTC #1429/2150: Born 10 Jan, 2000
    3.0L, Spec Stage 3 Clutch, LSD, Koni Sport Kit +more
  9. #9
    Dec 2011
    87
    yea ill take quite a few pics, i believe in paying it forward so whatever help i get, id like to pass on to someone else who might want to do this themselves or not pay for labor.
  10. #10
    Jul 2006
    Asheville NC
    295
    how is it easier to pull engine and trans??? this is isnt that hard of a job with hand tools in your driveway
    i didnt drain oil or trans fluid
    i didnt do half of what was on the list
    hmm i think i put the clutch disk through the inspection hole
    Quote Originally Posted by ChattavegasSE View Post
    I carry all my money in a mattress.
Page 1 of 2
1 2 LastLast
Similar Threads
  1. SVT MTX 75 - will a 99 Cougar MTX 75 work
    By enduro in forum Transaxle
    Last Post: 09-03-2011, 03:28 AM
  2. Replies: 4
    Last Post: 05-22-2011, 11:10 PM
  3. Replies: 71
    Last Post: 09-27-2010, 11:20 AM
  4. Contour doors locks removal, drive shaft removal.
    By glsaved in forum General Discussions
    Last Post: 03-29-2010, 09:53 PM
  5. MTX questions / removal and replacement help
    By OldSkool Member in forum Transaxle
    Last Post: 09-14-2006, 10:43 PM
Tags for this Thread
