Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: My very own '98 CSVT
    Mar 2009
    Onalaska, WI
    353
    Blog Entries
    1
    Default My very own '98 CSVT
    Picked this up from blu_fuz a short while ago. It's old and smelly but it's mine. There's lots of things that need to be addressed before it would be ready for a daily driver, but it's well on it's way. I'm hoping to sort everything out by spring and DD it. It needs a bath, but it's not registered and it's been too cold. I'm hoping to wash the salt off tomorrow. I have tons of love for the car already. She let me drive her home with a bolt in the trans so I'll return the favor and extend her life as long as life permits. Here's a list of what I need to do so far, and I haven't gone through the suspension or brakes yet.
    -Clean up peepers/fogs Headlights Changed
    -Check oil, and all fluids Oil is s***
    -Swap tire
    -Intake gaskets Check for leaks Upper changed + UIM cleaned
    -Shift knob swap shift knobs
    -clean/degrease engine bay
    -Swap skirts and bumper
    -Check/flush anit-freeze
    -Clean all brackets/hardware/mounts
    -Check and bleed all brakes/Swap rotors
    -Adress window trim
    -Clean wheels
    -Remove antena
    -Clean foglights and check for function/bulbs?
    -Remove mesh and repair
    -kill all rust
    -stabilize gas
    -check plugs/wires/compression
    -clean air filter DONE
    -check cabin filter
    -check tranny fluid Dirty
    -Swap suspension/knuckle, strut, rear strut mounts
    -check/fix exhaust or remove for spare
    -remove sub/amp setup
    -install radio
    -destickify windows
    -troubleshoot HVAC troubles
    -shift tower fish and fix DONE
    -clean glass/tranparent plastics
    -interior light replacement
    -swap rear reflector
    -optimize throttle body
    -Optimize y-pipe
    -Ebrake cable
    -Trunk release lever
    -Fuel filter
    -headlight wiring? gremlin?
    Aaaaand the pic...
    1998 SE MTX.. 0 RWHP.. CAI, SVT intakes & exhaust, Eibach springs, BAT struts, Fidanza, MSDS, Luk.. $700 salvage title, but it goes like Stig (KO'd) My Contour Forum - http://contoursvt.lefora.com/
    Jul 2007
    Middletown, Pa
    1,902
    Thumbs up
    Nice to see another one being saved rather than parting it out. Keep us posted on progress!
    00 Contour SVT #1914 BLK/PT 3L Hybid, Torsen, MSDS.
    00 Contour SVT #0157 BLK/PT stripped down and parting out (15.2 @ 89, 195whp)
    95 Mystique GS:16.989@ 82.02 MPH, 38.7MPG's RIP
    Apr 2008
    Ethridge, TN
    436
    What he said ^^^, I have to do the same thing, That one is much better off then my fixer upper.
    Black 1998 SVT Contour #3632 - "Decepticon" (Recovering From Battle)
    Black 1998 SVT Contour #6309 - (Recovering From A Serious A$$ Kicking)
    2013 Svt Contour Registry
    Mar 2003
    oneonta ny
    4,857
    Blog Entries
    1
    needs some love for sure...and a lot less sidewall!!!!
    i'd rape that car in your sig for parts to save the tour.
    --current cars: 1998 contour svt # 0165, 2009 mercury mariner premiere
    --past cars: 1996 contour se, too many mods to list!!, 1999 silfro svt, 1999 tropic green svt, and tooooooooo many others to list.
    welcome!
    very sharp TRed with MAD potential.
    99 CSVT #855 BLK/MNB w/ K&N, H&R, Catless test pipe, custom straight pipe exh.
    91 Miata #uhm many colors, MR C/O's, Mazda LSD, Heavy Ronal 16's, DD
    -Justin
    Mar 2009
    Onalaska, WI
    353
    Blog Entries
    1
    I've been looking for a cheap SVT like this that would be most likely parted out for me to save. This one is truly perfect for me. As luck would have it I had T-red skirts and a rear bumper that it needed. I had purchased them for my SE some time ago but never got around to painting. I took the grille and headlights from my SE while its down with a broken diff but I will not be taking any other parts off of it, aside from the shift knob that should match the T-red well lol. I'm not against owning 2 Contours so I'll fix the SE.
    I'd like to upgrade the brakes and suspension but I'll keep the 2.5 until it spins a bearing, throws a rod or whatever else it decides to do Duratec-style. At that point, if it has the original motor, it would be salvaged if possible. I will definitely ditch the "truck" tires. I keep thinking I should throw on my SE wheels just to get rid of them and also to see what SE wheels look like on an SVT for s**** and giggles but there's so much other stuff to do...
    Aug 2010
    Green Bay, WI
    113
    Keep up the good work bud! I'm excited to see the cars progress.
    May 2000
    Grand Rapids, MI
    26,530
    Blog Entries
    1
    Oh this is the one he had on FB with that terrible interior? Nice save. And I thought the black one I just sold was too much to save. This one is far worse.
    Former owner of '98 SVT #1,173. Need a 95-00 Ford CD manual? PM me
  9. #9
    Mar 2009
    Onalaska, WI
    353
    Blog Entries
    1
    Yes, it is the one on FB, it was also on NECO. The worn/stained carpet, missing console screws, 3/4" tear on one of the rear door panels and the "marring" on the HVAC controls are about the worst things interior wise. The seats are in great shape. It was a smokers car but I haven't found any burn holes. There are dings and dents and many other issues, but it's pretty solid for the most part so there wont be any issues of it being able to be saved other than time and money. I wanted one I could bring back from death row and that's what I got. Besides a blown front strut and worn rear mounts it drives well for the miles. I'll go through it all to make it safe though.
  10. #10
    Aug 2003
    Penfield, NY
    2,677
    Looks like it needs a bit of love but sounds like it's found a good home. At least the drivetrain sounds like it's pretty solid, I bought my 99 Cougar with a rod knock, diff that was toast/3rd gear grind and broken sunroof and got all that fixed up.
    Keep up the good work and get 'er up and running strong again!
    02 Cougar Sport - Vortech Supercharged - 13's or Nitrous!
    07 Focus SE ZX3 - FRPP Suspension/Gunmetal E1's/AVIC Navigation/Hitch - The DD
    97 F150 - Toy Hauler
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Replies: 17
    Last Post: 11-28-2010, 09:30 PM
  2. Looking for an CSVT T-Green Bumper, or a CSVT bumper period.
    By byako in forum General Discussions
    Last Post: 09-30-2009, 11:29 PM
  3. 98 csvt and 99 csvt 5HP diff... WHY?
    By SVT in forum Duratec Performance
    Last Post: 09-18-2009, 05:58 PM
  4. 99 CSVT Y-pipe dont fit a 98 CSVT?
    By Speed Demons in forum Exhaust
    Last Post: 12-14-2008, 12:12 AM
  5. Replies: 14
    Last Post: 10-02-2006, 02:10 AM
