Page 1 of 17
1 2 3 11 ... LastLast
Results 1 to 10 of 165
Thread: RWD CSVT: PRT's CDW-27 RWD conversion build thread.
    Default RWD CSVT: PRT's CDW-27 RWD conversion build thread.
    Some of you follow PRT on Facebook(facebook.com/prtautosport) and keep up on what we're up to at the shop....well, with yesterday's sale of the built trans we had sitting around, the build will officially be re-beginning, so I figured it was time for all of CEG to have a look.
    I've always had this build in the back of my mind since I picked up a world class t-5 trans some 5 years ago, and over those 5 years I have done a lot of research, a lot of planning, and a little dreaming. What really kicked this off this year, in addition to finishing the track SVT we've also always dreamed of building, was acquiring Hetfield's old SE for use as a mock-up chassis. It didn't take long and we had the front end fully dismantled and started taking measurements. The plan is/was to use this SE chassis to get a feel for everything, then clean up the design for final assembly into an SVT chassis. We weren't expecting to even look for that chassis till spring but couldn't pass up the deal handed down from Blu_fuz for a black E0 that needed more than a little work to live again. The body is straight with minimal rust and will make for a great car to run this in.
    "So what's the plan?!?"
    In true PRT style, the plan for this build is to stay clean, stay simple and end up with something that looks almost OEM. The car will run a turbocharged 3.0 Duratec mated to a T-5 transmission and driving a Mustang Cobra IRS. Unlike our track car there will be a more substantial interior, but severl changes are planned there as well. We intend to keep the outside lines of the car relatively unchanged, but there will be a few subtle touches that let you know this isn't your every day Contour.
    A huge thanks goes out to all who have helped me brainstorm, offered ideas and encouraged me to even get this far. While the build has only just begun, things should start coming together relatively quickly. So with that, a teaser until work progresses on the new chassis this weekend...
    99 SVT "BLKOUT2" - PRT street driven track #&$% - 13.904 at 102.58 | 98 SVT - PRT RWD conversion project car
    00 ROUSH Cougar - SOLD | 02 SVTF - New toy and R&D car. Future RWD?
    Owner/operator PRT www.prtautosport.com
    Follow development of CDW-27 performance parts: http://www.facebook.com/PRTautosport
    Feb 2005
    Tunkhannock, PA
    1,401
    Awesome man, good luck on it, if anyone can do it, it's you. One question I have is what are you going to do suspension wise on it? Surely stock spring rates and struts are going to be a problem, especially in the rear. Oh well, I'm sure that'll be one of the last things you look at, either way all of CEG is really excited.
    '99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...140K and currently dead. RIP
    '98 Dark Blue SE Sport V6 MTX 123K and counting, all mods from old, plus D2's.
    Out with the old, in with the....slightly older...?
    Feb 2011
    Hillsboro, MO
    336
    not sure if this has been disgusted but how are you going to get to the water pump once it's in the car?
    98.5 t-red Zetec mtx
    207,000 and counting
    i love bring my car into class, it give a new "special circumstance" every day.
    Quote Originally Posted by DanMyers View Post
    Front suspension will remain relatively unchanged with the exception of coil-overs and steering rack relocation. The current plan for the rear is a self contained system mounted to the Cobra IRS. Rather than using the standard Cobra strut/spring combo, I'm looking into using cantilevers and running coil over horizontally over the top. In addition to making it a clean install, it also means no more strut behind the tire, so I can use all of the stock rear wheel well the contour has to offer.
    Quote Originally Posted by jrichardson View Post
    Carefully? We've got a few plans in mind, but that is a back-burner item.
    Feb 2005
    Tunkhannock, PA
    1,401
    Awesome man, really looking forward to it, love the look of a cantilevered suspension.
    Sep 2002
    Fox Lake, WI
    14,066
    Dibs!
    *CLICK HERE ---> 1995 SE 3L WITH MATCHING TRAILER <--- CLICK HERE*
    23 Contour / Mystiques and counting......
    Oct 2008
    Dallas, Ga.
    1,693
    I'm definitely subscribing to this thread....good luck and I am looking forward to seeing this process.
    -99 E1 Black/MNB #1974 stock DD
    -98 E0 Black/MNB #0812 3L sold
    -98 E0 T-Red/MNB #0322 sold
    while it will make the WP much harder to change, it will improve access to the alt... trade one evil for another.
    Quote Originally Posted by Pole120 View Post
    Why? BECAUSE RACE CAR!
    94 Towncar RIP 20090730
    96 SE mtx, RIP 20100821
    99 Cougar, project car
    09 Fit mtx, DD
  9. #9
    What are you doing for management (I know its a long time off but my engine runs amazingly better on a standalone).
  10. #10
    Quote Originally Posted by 2000ZxT View Post
    Xcal with PRP is the current plan. The initial goal for this setup is to get it running with NA no changes from OEM. Obviously the cars wiring harness will have to be modified, but we are trying to make this as plug and play as it can be. Again, simplicity is key which is why we're sticking with the Duratec powerplant.
Page 1 of 17
Similar Threads
  1. V8 rwd csvt
    By DocStruthers in forum General Mods
    Last Post: 10-17-2011, 11:16 PM
  2. 3.0 Duratec FWD to RWD conversion...
    By fullyarmed101 in forum Duratec Performance
    Last Post: 09-25-2010, 11:04 PM
  3. RWD transmission for Duratec V6?
    By Swazo in forum Transaxle
    Last Post: 09-02-2010, 08:37 AM
  4. rwd contour drifting
    By turbo_fox in forum Pics and Videos
    Last Post: 11-12-2008, 12:04 PM
  5. rwd contour svt
    By drivebymashing in forum General Mods
    Last Post: 01-10-2007, 01:02 PM
