Results 1 to 7 of 7
Thread: Replace SVT headlight with non-SVT headlight?
    Default Replace SVT headlight with non-SVT headlight?
    My one Headlight on my SVT has the teo top tabs broken on it. If I was to take the headlight assembly out of a non SVT would it be the same? Or do they make any sort of superglue epoxy type stuff that would hold the plastic together where it is broken?
    Thanks
    Jul 2007
    Middletown, Pa
    1,899
    SVT and non SVT headlights are the same.
    00 Contour SVT #1914 BLK/PT 3L Hybid, Torsen, MSDS.
    00 Contour SVT #0157 BLK/PT stripped down and parting out (15.2 @ 89, 195whp)
    95 Mystique GS:16.989@ 82.02 MPH, 38.7MPG's RIP
    Jul 2009
    west michigan, Jenison
    411
    If you glue the tab back on or fab a new one use Jb weld. It is a grey epoxy that is a-lot thicker than the clear type. If you use the 5 minute setting Jb you don't have to clamp the parts to wait for it to harden.
    Now driving around in ronssvt's old car
    The rear bumper has been replaced. . . with mesh too
    Nov 2008
    Southern California
    42
    Careful on the color: a black SVT has black inserts inside the lights. I put one light from a silver/white Contour on my black CSVT and wondered why it looked so "different." After examining the original light I saw the internal color difference. Maybe a black Contour has the same lights.
    Dec 2001
    Gales Ferry, CT
    24,475
    Blog Entries
    93
    Quote Originally Posted by unpolire View Post
    this is not correct. All off the headlights are the same. What you have is a headlight that was "Hightowered". Someone openned up the headlight and painted the inside black. This is not factory at all.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Sep 2002
    Fox Lake, WI
    14,066
    Not true.
    *CLICK HERE ---> 1995 SE 3L WITH MATCHING TRAILER <--- CLICK HERE*
    23 Contour / Mystiques and counting......
    Ok thanks guys. For now I will try using jbweld expoxy to fix the plastic tabs. For some reason I thought JB Weld was only for metal so this is good news.
    Thanks
Similar Threads
  1. how to replace tensioner pulley on my SVT?
    By Knightrider620 in forum Duratec Maintenance
    Last Post: 10-26-2011, 12:42 PM
  2. SVT Headlight Removal
    By VitaminJ in forum Exterior
    Last Post: 10-02-2009, 09:52 PM
  3. white headlight surround like hvac/ svt gauges?
    By ConcepTrs913 in forum Interior
    Last Post: 05-10-2009, 06:34 PM
  4. What to replace the SVT with?
    By Tex in forum Common Interests
    Last Post: 12-29-2008, 06:53 PM
  5. SVT headlight help?
    By ckostler1 in forum Lighting
    Last Post: 12-25-2008, 05:22 PM
