Results 1 to 7 of 7
Thread: Nozzle Mounting
    Apr 2005
    Montrose, CA
    1,351
    Default Nozzle Mounting
    I feel kinda stupid even asking this, but I'm actually really confused. I have a NOS Shark 2 wet nozzle, which is the standard 1/16" NPT thread. I had hoped to tap it into the accordian hose directly, but obviously it won't thread into the rubber very well. I had considered a nut, but they don't make them in this thread, and there's the awful possibility of it getting sucked into the engine, so that's out. So, I'm left with getting a hard pipe, it seems. Can anyone verify; if I order the AEM intake, is the wall thick enough to thread my nozzle into once it's tapped?
    Thanks guys! So close to spray.... just gotta get it running again.
    '98 #3780
    Quote Originally Posted by blu_fuz View Post
    I want your tool...... how much for that?
    Jul 2004
    Wisconsin
    2,235
    Use a bulk-head fitting...Threaded sleeve.
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
    Jun 2006
    Center City, MN
    2,796
    usually the nozzle comes with a fitting, that has two nuts and one has a sleeve on it. they thread together (one on each side of the intake tube, whatever it may be) and the inside is threaded for the nozzle. i could take a pic of what i'm talking about if you do not have one you will need one. they can be found at any performance shop and even some auto parts stores that provide high performance accessories that are readily availible.
    98 CSVT-black. on it's second 3L swap. 219hp/211 trq
    May 2004
    Calgary, Alberta, Canada
    4,506
    i just drilled into the stock accordian tube and then siliconed the nozzle in. Its under anyways so you cant see ****.
    Its ghetto but it works. Best way would be spraying into the TB just behind the plate.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    Jul 2004
    Wisconsin
    2,235
    Quote Originally Posted by TRicker View Post
    What you described is what I posted...a bulk-head fitting.
    2000 Contour SVT
    SF - #542 of 2150
    Susp: Bat Euro Kit
    Quote Originally Posted by Matty K View Post
    I don't know if it will work for you, but I put my nozzle into the molded rubber fitting on the right side of th eaccordion where the tube from the rear valve cover vent goes. Then I aimed it at the TB. Then I just made a T fitting for the crankcase vent tubes and hooked them into the other side of the accordion. No cutting.
    My project website
    Apr 2005
    Montrose, CA
    1,351
    Quote Originally Posted by warmonger View Post
    That's a good thought, too. Looks like I'm in luck, NOS finally released a bulkhead fitting for their nozzles at Jegs. So I can use the stock accordian, awesome!
    '98 #3780
