Results 1 to 6 of 6
Thread: p0401 after new sensor
    Apr 2011
    Algonquin, IL
    357
    Default p0401 after new sensor
    Alright, I changed out all my O2 sensors and my DPFE sensor. all my O2 sensor codes went away after replacement and reset. However, now my P0401 is back. It is a new sensor. Ref and hi are on the proper ports. What else is the problem?
    ***Chasing the Contour dragon...***
    1998 ford contour SE 2.5L Duratec ATX spruce green
    engines: 2nd (2.5L at 195,000) CD4E: 3rd. 206,000 miles, last 50,000 severe service
    Dec 2001
    Gales Ferry, CT
    24,983
    Blog Entries
    93
    a sensor normally doesn't cause a P0401. that code is for blocked egr passage ways behind the TB.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
    Apr 2011
    Algonquin, IL
    357
    Hmmm, I thought I remember reading the DPFE is bound to go bad and throw the code on a lot of ford vehicles, but im probably mistaken. In any case, i'm going to have to pull off the EGR and clean. Is there anything I should be aware of before I try to remove it?
    Apr 2011
    Algonquin, IL
    357
    I am mistaken, if I replaced the sensor and it came back, common sense would be it is correct in its code. My bad.
    Dec 2001
    Gales Ferry, CT
    24,983
    Blog Entries
    93
    dpfe sensor would cause a P0402 ....
    - 12 Focus SE
    Apr 2011
    Algonquin, IL
    357
    yeah that is what I had before I switched it, then got a P0401. and for good reason. I opened up the throttle body, and it was a carbon mine! solid carbon through all the passages, up until where the inlet was, that was open.
    I blasted the passages with carb cleaner, the hole in the throttle plate was clogged as well, blasted the carbon plug out of there, I sprayed and scrubbed that with a toothbrush until it was clean, I had to chisel out the carbon from the passages with a small screwdriver, I disconnected the EGR valve, blasted cleaner up the passage and it ran out dirty and chunky for a bit but then it ran clear, scrubbed the rest of the EGR passages with the toothbrush, blasting it with carb cleaner, got it all opened up, finished cleaning the throttle body, bolted it up, and it feels like it runs better than before. might also be the fact that I also cleaned the layers of carbon off the throttle body as well though.
    BrApple you are the man!
Similar Threads
  1. P0401
    By kcobra in forum General Troubleshooting
    Last Post: 03-08-2012, 05:55 PM
  2. P0401 help
    By TikeCSVT in forum General Troubleshooting
    Last Post: 02-08-2009, 03:29 AM
  3. P0401 and P1151
    By theoldwizard in forum General Troubleshooting
    Last Post: 01-04-2009, 05:00 PM
  4. P0401 still
    By AliasJerk in forum General Troubleshooting
    Last Post: 05-31-2008, 06:50 PM
  5. P0401
    By The Digital Slacker in forum General Troubleshooting
    Last Post: 06-03-2007, 09:29 PM
