Results 1 to 8 of 8
Thread: got sum free 17s
  1. Default got sum free 17s
    whats up guys?
    Well i got lucky and scored free 17swith kumho tires. The only problem is that there bolt pattern is 100 and 114. my contour is 108 what can i do? i really want these rims. can i get a spacer or somehting? please help
    Sep 2000
    Louisville, Ky
    9,565
    they wont fit....not unless you have them custom drilled, but that completely ruin the look of the wheel if you dont have center caps that cover the lug nuts.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    Jul 2004
    Minneapolis, MN
    512
    Im sure you could buy an adapter kit that bolts on to your studs to change the pattern, I had 2 adapters for my old 'stang back in 99', I had 13's (lol) that hit the calipers and had to push the rim out a lil to clear. But in the end, itll prob cost at least 200 bucks and that aint worth it. Back then rims were expensive, not like now where you can scour Ebay for a good package price. Ps. The adapter looked like this, but a 4 bolt in your pattern may be hard to find http://www.skulte.com/index.php/cPath/21 In the end, it just is not worth it, some say it put unecessary weight on the ball joints and things of that nature. but the stang was cornering fine, the price of these adapters are ridiculous sometimes. My advice would be to sell em to someone who can use em.
    1998 Contour Svt Born 5/12/97 #897 of 6535 or 2487
    (depends how you look at it)
    Aug 2003
    State College, PA
    964
    good call, not worth it at all. at least you could make a profit since you picked them up for free and use the cash to find rims that will fit without adapters and all that other stuff.
    99 contour se
    17" Enkei CDR9
    A few little mods
    Post pics, i'm interested if you're selling.
    You would probably need something like this:
    http://www.ezaccessory.com/Wheel_Ada.../4425-4100.htm
    Don't forget that adding adapters will probably change your offset. Unless you want to get the "sticking out" past the fender look, you should either match it with high positive offset wheels or install it on a vehicle with "medium-low positive offset", Neutral or Negative offset.
    99 Contour SVT #1690 / 2760
    - No engine performance mods (yet)
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Sell them and buy 4x108!
    May 2006
    Glen Ellyn, IL
    2,452
    Quote Originally Posted by todras View Post
    +1
    10 carkjagk
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
