Redlineracer12
Addicted CEG'er
I have a set of OZ Superleggeras in 18x7 42mm offset 4x108 bolt pattern at around 17lbs a piece. Three of them are in decent useable condition, but one of them should be straightened before use. The wheels are no longer available new, so you would have to have them straightened by a wheel repair shop or source another one used. I heard it was in the neighborhood of $125/wheel to get them straightened. The finish is a little aged looking, but not bad from more than 5'. I was planning on repainting them a different color before I found the bend. They all held air though with tires on them, I bought them in this condition and have only since taken the tires off and washed them. So I have never used them myself.
I will sell as a set for $400 + shipping , or would maybe entertain selling a few of them individually.
Wheels are near St. Paul, MN.
Pictures of individual wheels:
Very large version: http://shineyphotos.com/OZs/IMG_0662.jpg
Wheel #1 has the worst bend, I wouldn't use it in it's current state. It also has a flat spot on the face of the rim near the Superleggera marking. You can see the paint is cracked on the nearest spoke.
Very large version: http://shineyphotos.com/OZs/IMG_0661.jpg
Wheel #2 is slightly bent, I would probably only use it in the rear as is. It has the most curb rash.
Very large version: http://shineyphotos.com/OZs/IMG_0660.jpg
Wheel #3 has a very slight tweak to it, but I think you could probably run it in the front or rear. It has a couple small dings in the lip, but no major rash.
Very large version: http://shineyphotos.com/OZs/IMG_0659.jpg
Wheel #4 is straight, with no rash or major dings.
