Will the 3.0 liter block fit on a 96 ATX
If it is a V6 ATX, yes it will. If you intend to use the car hard, it may not be a good idea though, as the ATX isn't all that strong.
Jim Johnson
98 SVT
03 Escape Limited
Yea its a V-6 so what kind of mods would someone have to do to convert from 2.5 to 3.0
Ok you've got a lot of searching to do...In a nutshell...Buy a 2001+ Taurus/Sable motor. Either a) port the heads and swap over 2.5 intakes or b) keep the 3L intakes and fab up some vacuum lines and replace some stuff then drop it back in. Search the old forums. A lot of info there.
Need a CSVT
Daily Driver: 2000 Ford Taurus SEL (Duratec)
How much of a power gain have you got from a 3L swap
You have a 20% increase in displacement. That should give you a good idea.
Jim Johnson
98 SVT
03 Escape Limited
which engine controller gets used 2.5 or 3.0??
00 Contour SVT Black
#557 of 2150
Fabricated Nov 24 1999
short ram intake/magnaflow exhaust/short throw shifter/ MSDS headers and more to come
Use the one that came with the car, but it will need a tune.
Jim Johnson
98 SVT
03 Escape Limited
the controller from my SVT or the one from the donor car??
#557 of 2150
svt
mymessageisnottooshort
3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
NEW 4 bolt control arms $105!
NEW GCK axles $65 each!
PM me for details
