As some of you may know, I have been having a horrible time with my car lately with problem after problem after problem that always seems to be a mystery. In the last two years I had the car running good for about 200 miles at most. I know a lot of the problems are due to the extensive modifications done to the car, but none of them should have given me alll these problems. So the time has come, I give up on it for now. I need to be spending my time and money on something that isn't just going to run into a dead end every single time I put my blood sweat and tears into it. I will be making my last large purchase on a carport for the car and will be towing it to a family members house about 3 hours away that has plenty of land I can store it at. Heres some pics and a list of the modifications I have done to it in the last two years.
-Oval port 3L
-SVT cams
-SVT radiator
-ST220 intake manifold
-Optimized 65mm throttle body
-NPG cold air intake
-MSDS headers
-MSDS y-pipe
-Trubendz 2.5” cat delete pipe
-Magnaflow 2.5” custom catback
-DMD crank pulley
-Escape oil pan
-8.5mm Megnecore spark wires
-NPG tune
-Clutchnet stage 3 clutch
-Fidanza light weight flywheel
-Quaife limited slip differential
-3.5 final drive ratio
-HMS keyed shift tower
-80A poly filled mounts
-Fidanza short shifter
-Koni/ground control coilovers
-Subframe connectors
-Jaged rear strut tower bar
-Kenwood dnx7100 7” touch screen
-Voodoo shift knob
-AEM wideband gauge
-Relocated optima red top battery
-OEM carbon fiber hood
Not to mention the parts still waiting to be installed
-BAT 21mm rear sway bar
-SVT front sway bar
-Stangkiller front control arms
-TZT adjustable endlinks
-NPG turbo kit
-Accusump
As well as the parts I was going to buy as soon as the car was running good
-TZT rear toe arms
-PRT track version rear control arms
-Reinforced rear subframe
-DSS 3.9 600HP axles
-Oil cooler
Not to mention all the parts I replaced just to have brand new everything, as well as the things I am forgetting.
It has even been kicked out the garage already, because I am soo done with it.
-Oval port 3L
-SVT cams
-SVT radiator
-MSDS headers
-MSDS y-pipe
-DMD crank pulley
-Escape oil pan
-NPG tune
-Voodoo shift knob
-AEM wideband gauge
-SVT front sway bar
-NPG turbo kit
-Accusump
-TZT rear toe arms
-Oil cooler
