I am researching a 3.0 swap into my 1999 SE and wanted to see if anybody has tried to use the MPV's 5 speed auto trans in a Contour. Not Sure the stock contour PCM will be able to control it, but it could be a pretty sweet swap if so.
the PCM isn't going to be able to run the transmission. And I have a feeling that it might have more or different sensors which are not wired in the Contour PCM making it very dificult to make work.
