Results 1 to 4 of 4
Thread: cold plugs...
  1. Default cold plugs...
    any suggestions on what kind of a cold plug i should use for a 50-75hp wet nitrous for 99 tour? nkg zr6?? champion copper core...?
    May 2004
    Calgary, Alberta, Canada
    4,506
    NGK TR6
    10motherfugginchars..
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    May 2006
    Sunny San Diego California
    234
    Thumbs up Tr6
    Quote Originally Posted by Tourige View Post
    NGK TR6
    I concur. You should have no drivability issues with them, as long as it's not too cold.
    Stock heat range plugs for any shot under the 75HP range. NGK or Autolite are brand good choices.
    If you want to run a larger shot then put in 1 step colder. However take them out when you are down running it. They noticeably drop the efficiency of the engine in any weather. In cold weather they are just horrible about it.
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
