My driver side door handle is junk. I can barely open my door from the outside anymore. Its embarrassing quite honestly... Its bad enough I drive a contour.
Is this something that I can fix myself, or is a new handle required?
11 second daily driven Evo VIII
Mountaineer- Winter beater
Used to own- First NPG Turbo'd SVT
Well, first you have to dignose why it doesn't work properly. Thenyou can determine if its somehting you can fix, or if its something that needs to be replaced.
And if you don't like your contour, sell it.
2000 Contour SVT
SF - #542 of 2150
3L: SVT Cams/LIM/UIM/Optimized TB/MAF
HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
Tuning: Xcal2 with PRP
Susp: Bat Euro Kit
My passenger side door used to be hard to open until I sprayed some lube on the striking mechanism. Give that a try.
'01 Mercury Cougar
'04 Mazda6 S Wagon
'03 Kawasaki Z1000
Unaware of this said mechanism, where can it be located.
03 Mustang Cobra Convertible # 476 out of 5,082
93 Cobra
01 Lightning
99 LX Contour - Sold 2/23/09
I had the problem with my driverside handle being a ***** to open too. It thing the latch latches on to had gotten bumped back over time, just loosened the screw and pushed it forward a half a centimeter and now the handle works 100% of the time.
98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
An easy way to tell if your latch mechanism needs lubed...
Push on the door, pull up on the handle, then pull the door open, release handle.
Same procedure as normally opening the door, except you push on it while pulling up on the handle.
If the door opens perfectly, you need lube. And not WD40! Get some real lube...
IIRC, my brother sprayed silicon lube in there when he was watching my 96 GL (he grew tired of the hard to open door!)...
\m/ 2009 Jetta TDI \m/ 2003 Sentra SE-R Spec V \m/
