Results 1 to 9 of 9
Thread: Trunk light
    Jun 2000
    rochester
    401
    Default Trunk light
    I recently swapped my pre 98 decklid back to a post 98 decklid and i noticed my trunk light is not working. The bulb is good i followed the wires all the way back to the drivers side rear door. What causes the light to come on in the trunk? The 99svt has a spot for a switch to mount right behind the driver side hinge. my very early build 98 se has no spot for a switch but the trunk light always worked in it. Any one know what triggers the trunk light to come on?
    Feb 2005
    Tunkhannock, PA
    1,418
    Not sure, mine never shut off.
    '99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...140K and currently dead. RIP
    '98 Dark Blue SE Sport V6 MTX 123K and counting, all mods from old, plus D2's.
    Out with the old, in with the....slightly older...?
    Feb 2011
    Akron, Ohio
    124
    Im looking for the same answer. My light is not shutting off... there has to be a switch somewhere, when I first couldn't find it I thought it might be on a timer of some sort rather than a button like switch... so I crawled into the trunk and waited... needless to say nvr went off. I'm going to check my owners manual and other online sources. Should be able to find it. Might be a thread here. Checking that too.
    1996 Ford Contour GL Midnight Blue 62k 2.0L Zetec Auto wrecked, front end damage. =(
    1999 Ford Contour SVT Silver 230k 3.0L MTX
    Jun 2007
    Eatonton, GA
    660
    I had the same problem. It ended up killing my battery over and over again. I'm not sure why. So I just took the bulb out.
    2001 Ford F150 Amazon/Gold Supercrew
    180k and still like new.
    1995 Toyota Camry Charcoal XLE
    166k wife's car.
    Jun 2000
    rochester
    401
    I have given up on trying to figure out whats going on back there. I have power in the trunk from the amplifier. I am going to make my own switch and run it that way.
    Hey guys call me stupid but where is the trunk light bulb? I have a pre 98 trunk lid on my 99,
    Thanks
    Nov 2003
    Plainville, CT
    8,109
    It's not on the trunk lid so the year of the trunk lid makes no difference. It's mounted under the rear deck towards the edge of the trunk opening.
    1998 SVT Contour 3L (B/MNB) #542 (His)
    2000 SVT Contour (SF/MNB) #1533 (Hers)
    2003 BMW 540i M-Sport (6 spd)
    2002 Cougar XR - XR Racing Red
    2002 Lexus IS300 SOLD!!
    May 2011
    Syracuse, UT
    244
    look toward the front of your trunk space on the drivers side theres a switch dirreclty in line with the hinge...
    Jared Adams
    Street whore 2000 contour svt #1649 3l vortec supercharged heavily modded
    TURBO 10 psi 98 SVT Contour #0004 heavily modified
    soon to own me a fox mustang
  9. #9
    Apr 2005
    Aurora, IL
    3,493
    Quote Originally Posted by jtidaho View Post
    This, in my 95 it broke off which caused the light to never shut off. I just taped it in the off position! Perhaps check the switch, perhaps it's become disconnected somehow.
    Dave
    #905 of 2150, born 12/14/99 \ knauberized \ Pioneer H/U \ topshop eyelids \ painted oval
    '98 Windstar 3.8L - RIP
    '06 Grand Caravan SXT
    In Chicagoland, need an OBDII or ABS scan, look me up.
Similar Threads
  1. Trunk Light?
    By Lord Stanley in forum Lighting
    Last Post: 05-14-2008, 11:04 AM
  2. CF Trunk Cannot mount center light....?
    By qbcsvt in forum General Troubleshooting
    Last Post: 07-24-2007, 09:50 AM
