RAD Merc SVT
I don't know if this is the right place to post this so please move me if I am wrong.
So today I will be putting my old 2.5L up on the engine stand. It had a rod knock from like 3500 RPM to 5000 RPM or so and then it suddenly got worse and knocked at all RPM's really loud. So I stopped driving it before it threw a rod.
I am very curious as to why these engines are so notorious for rod bearing failure. People say bad rods, but I don't think the rod casting process these duratecs use is any weaker than anything else. People say oil drain back, but then wouldn't the main bearings be the first to go? Could it be poor quality bearings? Could it be too much harmonics on a poorly balanced crank? Does evrybody who drives these cars beat the crap out of them? I want to figure this out or at least try to make a little progress.
I will be taking the bottom end apart and checking each rod for bearing damage, I will be measuring the rod bearings ID from top to bottom and side to side. (I think if the rods stretched they would be longer top to bottom and narrower side to side)
I imagine this has all been done before but I notice most rod knocks throw the rod so we cant measure it. If there is anything else you guys think I should measure let me know I will be posting pictures.
A little more info. This is a non SVT 2.5L the original owner put on a DMD (I am not sure what mileage) I can't remember when the rod knock started but I stopped driving it at about 75000 miles when I knew the rod was about to go. I was agressive on this car within reason it was raced a few times and spent alot of time at WOT (which most engines should be able to withstand) It got synthetic (Royal Purple Napa gold filters) oil changes every 5000 miles since I bought it at 60000 miles. (I don't know what the original owner did but he took great care of it so I imagine it was close to the same) If there is anything else you guys would like to know about the engine let me know
I am curious to learn so help me out. Thanks guys
-Brian
-Brian
