Thats unfortunate that your coating failed. Your experience is not necessarily a common story though. If you didnt already, you should consider pursuing warranty replacement, as that coating should only fail if it wasnt properly applied in the first place (unless it took some damage somehow such as bottoming out while driving or getting dropped before installation). Either way, its no reason to get snotty. Just state your position so the OP can get the input he's looking for. You did point out something I didnt really address though, that the Y-pipe most definitely gets wet, and even though the stock one is just steel, any opportunity to use a better product should not be passed up.
